Relay trigger wire connection for aux fuse block - optimal place to tap? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 01-02-2009, 11:24 AM Thread Starter
aperider's Avatar
Just installed a 8-circuit power block for aux stuff like lights, GPS, radar, etc. I need to find a good on/off source for the power block relay to activate it when key is turned on. Can someone point me in the right direction?
2003 DL1000
aperider is offline
post #2 of 8 Old 01-02-2009, 11:33 AM Thread Starter
aperider's Avatar
Nevermind. Found the rear brake adapter kit from Eastern Beaver.
aperider is offline
post #3 of 8 Old 01-02-2009, 01:22 PM
randyo's Avatar
I hope it's a tail light kit, if you connect to the brake lite circuit, it would only turn on when you apply the rear brake:rolleyes:
I recommend not tapping any circuits, rather find an unused switched plug, tapping compromises the integrity of your wire harness
I pluged mine into the orange & white wire in the dealer test plug at the recomendation of Suzuki NA tech support
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #4 of 8 Old 01-02-2009, 01:26 PM
tmcgee's Avatar
Originally Posted by randyo View Post
I I recommend not tapping any circuits, rather find an unused switched plug, tapping compromises the integrity of your wire harness
Eastern Beaver's kit is a plug-in tap using appropriate connectors. It doesn't compromise any wiring. I, on the other hand, might well give you nightmares with some of my wiring modifications. I'd rather do things the way Jim does, but don't have his patience for hunting down parts.
tmcgee is offline
post #5 of 8 Old 01-02-2009, 01:33 PM Thread Starter
aperider's Avatar
Sorry, I do believe it is the tail light harness NOT the brake light.
aperider is offline
post #6 of 8 Old 01-02-2009, 02:18 PM
The E/B brake light switch connector takes the ignition on hot connection to the rear brake light switch and feeds it to a wire that can be used as a trigger wire. It takes power from the O/G wire to the switch, not the W/B wire out of it. It also passes the B/W ground through the OEM connectors. It's a fine solution. http://www.easternbeaver.com/Main/Bi...l#brakeadaptor
post #7 of 8 Old 01-02-2009, 03:04 PM
V-Strom Charlie's Avatar
Location: NW Arkansas near beautiful Eureka Springs & the famous Pig Trail - best riding in the Ozarks
I tapped into the brown wire inside the wiring loom on the right side of battery box. Simple task, Just make sure your connection is solid. I managed to tape it tight after installing it. No problems after 2500 miles in varying weather.
Charlie
Eureka Springs, Arkansas - Best twisties in the Ozarks!
De-stickered and well farkeled DL650 K6 Wee is my Baby
First Bike: 1957 Cushman Model 62 Sport
Bike most disliked by LEO's: 2007 Motoguzi Breva 750
Current Bike: Suzuki DL650 K6 V-Strom
Favorite Bike: To be determined
V-Strom Charlie is offline
post #8 of 8 Old 01-02-2009, 03:26 PM
roger123's Avatar
Jim's stuff is top-notch and the prices are very fair. I could make a lot of the stuff but it's just nice sometimes to buy something that works right out of the box with NO messing around!!
I have the brake light trigger wire, the headlight modulator and the headlight cutout switch. All plug and play, very nice and super quality.
Roger ('14 Tenere ES, COG 5903)
roger123 is offline
