Is this big enough - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 11-14-2008, 02:46 PM
RidgeRunner
Is this big enough
To power a fuse box. Or do I need to get the other one that is like $35? I read the description and I thought that this would run the fusebox, but now I have my doubts. If I have my heated grips, jacket liner and aux lights running will this carry the load? Thanks in advance for your help.
Rear Brake Connector Relay Switching Adaptor
This pair of Sumitomo 2 pole connectors makes it easy to get a switched power source for switching a relay to control a fusebox or any other accessory on the bike.
All wires are factory crimped into the connectors and sheathed with high temperature VOX sheathing.
Add your own push on terminal to connect to your relay, or use a Posi-Lock to connect your switching wire directly. The adaptor is 24" (61 cm).
No more routing wires way up front, or tapping into the bike's wiring. The rear brake connector is close to an under seat fusebox and is wired to the same circuit as the bike's heated grip connector.
The rear brake connector's hot lead is hot whenever the bike is turned on. It is a perfect place to tap a small current for switching your fusebox or any other accessory.
NOTE: 650 ABS models have the brake light connector mounted under the coolant overflow tank. It's a bit more work to access and connect but it's not that difficult and still allows a plug and play connection without tapping a wire.
VStrom Rear Brake Connector Relay Switching Adaptor - $6.95
Quantity:
This is from eastern beaver. Trying to link it but cant get it to work.
RR
post #2 of 6 Old 11-14-2008, 04:17 PM
All that does is provide an ignition switched power lead for a relay to power a fuse box. It is basically the blue wire in the diagram. You still need the relay and fuse block. They are all included at http://www.easternbeaver.com/Main/Pr...3_circuit.html with enough connections for the three devices you want to connect.
post #3 of 6 Old 11-14-2008, 06:24 PM
RidgeRunner
I already have a Blue Seas fuse box so I do need that do I? I need this, correct?
30A Centech AP-2 Relay Kit for VStrom (no AP-2)
This Kit puts the AP-2 in the underseat tray. The relay goes behind the battery, and the adaptor plugs into the rear brake light connector. Everything you need is included except the AP-2: cable ties, two 30A fuses, and the Kit comes with the AP-2 terminals attached.
How come when I copy it it copies everything except the pic.
RR
post #4 of 6 Old 11-14-2008, 07:19 PM
Right. If you have a fuse block that's all you need. Do add a voltmeter though. You won't be able to run all that stuff at once at full power without running down the battery. When the voltmeter reads under 12.6-12.8V, the system will be in discharge mode.
post #5 of 6 Old 11-14-2008, 11:00 PM
RidgeRunner
Thanks greywolf, I appreciate the help. I suck when it comes to wiring, I know it should all be straight forward but I guess it just scares me too bad or something.
RR
post #6 of 6 Old 11-17-2008, 07:23 PM
Stromtrooper.com Sponsor
Jim Davis's Avatar
The AP2 Kit is for a Centech AP-2 fuse panel only.
For a Bluesea box, use this Kit:
"30A Fuse Panel Relay Kit for VStrom (no fuse panel)
This Kit fits a Centech AP-1 or a BlueSea fuse panel so if you already have one of these fuse panels, you can buy my fabulous kit and get the same easy installation as my complete Kits above."
http://easternbeaver.com/Main/Bike_S...om/vstrom.html
Jim Davis, Owner, Eastern Beaver Company:
http://easternbeaver.com/ - Motorcycle Electrics: 2007 DL1000 with 16/43 gearing, Superbrace, Tokico 4 Pot fronts, BackoffXP, H4 Dual Relay Kit, PC-8 Fusepanel, 2 Powerlet Sockets, Suzuki Centerstand - 1988 Africa Twin 650, 1990 VFR 750.
Jim Davis is offline
