Installing a Kisan signal minder(?) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 1 Old 10-11-2008, 01:05 PM Thread Starter
bwbcpa's Avatar
I'm trying to install a signal minder on my '05 Vee. I found the relay box under the seat to do the wiring, but the wires going to the relay are on the bottom side. I tried to unplug the wiring harness and pull the wires to work on them, but I couldn't figure out how. Then I thought I could snap the fuse box and relay loose from the mounting bracket, but I didn't have any luck there either - I was afraid I would break the tabs off the battery box. Anyone out there been through this and have any suggestions?
bwbcpa is offline
