RAM Mount Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 14 Old 03-07-2016, 11:36 PM Thread Starter
RAM Mount Question
I have my GPSs mounted on RAM mounts on the FJR and V Strom. Recently when going over bumps, the arm kind of slips on the ball and it falls. I have it tightened as much as I can.
Have any of you ever had this happen and if so what can I use to either make the ball grab the socket better or even make it tacky so it cannot slide or rotate on its own?
Thanks,
Howard
Spring Hill, TN
15 FJR1300, 15 VFR800 DLX, 99 Excelsior Henderson Super X, 91 HD XLH1200 Sportster, 77 Honda CB400F SuperSport, 14 Kawasaki EX300 Ninja
cyclemed is offline
post #2 of 14 Old 03-08-2016, 05:01 PM
sbeadg's Avatar
I haven't had that problem but you might try orienting the assembly to reduce the leverage arm torque it needs to resist going over bumps - if you can.
richlandrick likes this.
'15 Tiger800 XRx
'99 Triumph Thunderbird Sport
'89 Honda NX250
"Why don't I have tattoos? For the same reason you don't put a bumper sticker on a Ferrari."
sbeadg is offline
post #3 of 14 Old 03-09-2016, 09:36 AM
Rick505's Avatar
I wonder how long an arm are you using?? I know RAM makes so many possible combinations I lose track. Mine uses a shorter 1-2" arm and it does tighten down so it doesn't slip. I also believe RAM really stands behind their products.....give them a shout for assistance. Good Luck.
Rick505 is offline
post #4 of 14 Old 03-09-2016, 09:40 AM
Macdoc's Avatar
There is not a lot of clearance but a small piece of inner tube or something else along those lines should give you some addition friction.
Illinois likes this.
Canada 2018 CB500x >2009 CBF1000 sold 10 Wee ABS sold 09 Burgman Exec sold 10 NT700v sold
Australia> 04 KLR650 93 ST1100 sold
Macdoc is offline
post #5 of 14 Old 03-09-2016, 09:41 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
All the necessary information for Ram Ball nirvana is here.
Use the shortest arm possible.
Keep the arm as close to vertical as you can.
richlandrick is offline
post #6 of 14 Old 03-09-2016, 07:23 PM
RCinNC's Avatar
If all else fails, pick up some E6000 adhesive at the hardware store, and spread a thin layer on the inside of the socket portion of the ball mount and let it dry thoroughly. It will increase the friction between the ball and the inside of the socket and hold the ball in place. I use a combination of homemade ball mounts (made from hardware store threaded balls) and the socket from RAM, and the E6000 holds everything steady.
RCinNC is offline
post #7 of 14 Old 03-09-2016, 10:05 PM
Dry Heat?
Outbackwack's Avatar
Scuff up the inside of the arm with Emory cloth or something and wipe down both the arm and ball with nail polish remover or Goof Off.
Get busy living, or get busy dying...
http://www.visitedstatesmap.com/image/AZCOCTILINIAKSKYMEMAMOMTNVNHNJNMNYOHPASDTXVTVAWVWY  sm.jpg
Outbackwack is offline
post #8 of 14 Old 03-09-2016, 10:32 PM
blaustrom's Avatar
Seems you are either at the end of the thread of the clamping screw or you bent the extension (very hard to do I think) or the extension castings are just a little burred on the mating faces.
Take the extension apart, check if its bent. If not remove some material from the mating areas so you can subject more pressure at the ball/ socket interfaces. If none of this works replace one or both balls, hopefully the replacements will be a little larger in diameter and allow proper clamping force. Good Luck!
blaustrom is offline
post #9 of 14 Old 03-09-2016, 10:38 PM
Sgt Schultz's Avatar
Be careful when tightening the clamp, I actually broke one when over tightening.
I know nuffink, I see nuffink, It was not me, I was not here.
IBA #45920
FarRider #299
2015 Wee Strom "Piglet"
Givi crash bars, Barkbusters, Ravetech Bash plate, Ravetech Rad guard, Ravetech over dash Ram mount, Hyperlite flashing brake lights, Madstad bracket and screen, Augustus wind deflectors, Spot 3, UHF two way radio, Garmin Zumo GPS, Starcom intercom, Fuze block.
SW Motech Centre stand, Suzuki power outlet. Bike Alarm, Screaming Banshee horn, Led Flood lights, Tool tube, Andy Strapz Expedition soft panniers and frames.
Sgt Schultz is offline
post #10 of 14 Old 03-09-2016, 10:45 PM
Bugzy's Avatar
Maybe your ball is too small for the clamp. See if you can swap it for a larger one. I have never had any of mine slip on gravel/rock/dirt roads, I have 4 on my bike.
Bugzy is offline
