Available amperage on 04 1K? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 09-21-2008, 11:35 PM Thread Starter
PapaWally's Avatar
Does an 04 1K have sufficient amperage to run all these at the same time?
Gerbings jacket = 77W on high
PIAA ATV lights = 30*2 = 60W
Symtec grips = 36W on high
Sirius radio = 1W ?
Autocom pro = 2W ?
cell phone charge = 1W ?
batery monitor = 1W ?
accessories = maybe 150 watts total?
'04 DL1000
'98 R1100RT
XR650 XR600 XR350 XR350 XR350 XR200 XR200 XR75
Husky 250 / 360
PapaWally is offline
post #2 of 9 Old 09-25-2008, 08:30 PM Thread Starter
PapaWally's Avatar
I've been watching the battery monitor
Jacket
Grips
autocom
Sirius
NO PIAA
and battery monitor goes red at idle 1100 rpm
turns green going down the road
I would imagine that if left idling the spark would
adventually deminish and the bike would stull???
Comments?
'04 DL1000
'98 R1100RT
Husky 250 / 360
post #3 of 9 Old 09-25-2008, 08:39 PM
SCraig's Avatar
You have about 100 to 125 watts to work with at speed. I think I read somewhere that this is at about 5,000 rpm but I don't remember for sure. At idle, significantly less. There's no way you're going to be able to run all of that though.
Scott Craig - Nashville, TN
SCraig is offline
post #4 of 9 Old 09-25-2008, 09:30 PM
randyo's Avatar
Sirius radio = 1W ?
Autocom pro = 2W ?
you should be ok, when you come to a stop and the bike idles with turn signal and or brakes on you may momentarily go into a discharging mode
how often do you have your jacket liner or grips on high?
the 1000 has 25 or more watts more capability than the 650
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #5 of 9 Old 09-25-2008, 10:24 PM
Total watts output at 5000rpm.
2002 DL1000 - 350W
2003 and later DL1000 - 400W
2004-2007 DL650 - 375W
2008 and later DL650 - 400W
post #6 of 9 Old 09-26-2008, 10:17 PM Thread Starter
PapaWally's Avatar
Do you think it would hurt to run on the "red" line...
ie. ..Discharging at idle and charging when rolling?
Bad for battery or charging system?
If severly overloaded, what is the result?
Other than dead battery of coarse.
'04 DL1000
'98 R1100RT
Husky 250 / 360
post #7 of 9 Old 10-09-2008, 06:20 PM Thread Starter
PapaWally's Avatar
Well...I must have pushed the electrical system too hard...
no instrument cluster
no lights
no horn
engine runs fine
time to troubleshoot
'04 DL1000
'98 R1100RT
Husky 250 / 360
post #8 of 9 Old 10-09-2008, 07:45 PM
Check the large connector under the rubber boot inside the left fairing cowling for discoloration indicating an overheated and failed connection.
post #9 of 9 Old 10-10-2008, 07:50 PM Thread Starter
PapaWally's Avatar
"Signal" fuse was blown
15Amp
Not sure why yet
Thanks greywolf, I'll look at that
'04 DL1000
'98 R1100RT
Husky 250 / 360
