Considering a Garmin GPS 58LM or 68LM - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 32 Old 01-12-2016, 11:44 AM Thread Starter
I'm considering mounting a Garmin Nuvi on my 2012 DL650 I ride probably 70% pavement and 30% gravel roads. I'll use the unit in both car and bike. I'll buy the life time map update option and update with my Macbook Pro. I'm running Yosemite OS X and will upgrade as Apple Software upgrades. I'm NOT tech oriented and I'm susceptible to frustration when faced with complicated tech upgrades.
I'm trying to research the fallowing:
1. I'm reading GPS map upgrades can be frustrating and complicated. Any comments on Mac Yosemite compatability to Garmin?
2. I'm thinking simpler is less problematic. Looking at Garmin models 58LM & 68LM, mounted above the dash on my 2012 DL 650. Any comments on either of these models? I can't justify the price of the Zumo units. I avoid riding in the rain.
3. I bought a bike specific, SW Motech GPS over the dash mount last year but have not mounted it yet. I'm hearing that there might be a vibration problem, with this mount, on gravel roads. Any adjustments or do it yourself tweaks to reduce vibration?
4. Any thoughts on sun light complications or add on shade screen visor?
Thanks for your comments. There seems to be so much marketing hype and I'm trying to sieve out the facts.
keuka is offline
post #2 of 32 Old 01-12-2016, 11:48 PM
Rolex's Avatar
I don't know about the models you have chosen but many Gramin Nuvi's will not give instructions via Bluetooth to your helmet.
They have Bluetooth but will not give instructions.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 32 Old 01-13-2016, 10:29 AM Thread Starter
The units I'm looking hardest at are the 58LM and 68LM. They are at the upper end of the Garmin Nuvi "Essential" or basic series. They're touch screen models with basic GPS functions. They don't have Voice Command, Bluetooth, or trip planner.
I'm old school and will also be using paper maps and compass. I'm considering a GPS for mostly congested areas and to supplement paper maps.
. My thoughts are to buy life time map upgrades but stick with a simple unit to reduce update problems. My internet reviews seem to indicate more problems with the complex or high end GPS units.
keuka is offline
post #4 of 32 Old 01-13-2016, 10:56 AM
568v8's Avatar
old school
I also love paper maps and use them for planning in conjuction with other tools but you will most likely learn how and want to plan your rides with detailed routes and instructions. I think you should consider a GPS unit that has plenty of route capability.
I'm a serious user of a Garmin Zumo 550 on the bike and love the Garmin Nuvi 3597LM in the car.
Being able to modify routes on the way right on the unit, when meeting locals while stopped at restaurants and of course detours and closed roads, is very important.
Road Toads Charter Member - old guy goes stromabout on a 2007 Vee and finally has touched all of the 48 contiguous United states and the 10 Canadian provinces.
568v8 is offline
post #5 of 32 Old 01-13-2016, 12:57 PM
dravnx's Avatar
The bigger problem with non-moto specific GPS units are the delicate little USB charger connectors. They're just not up to the vigors of being mounted on a motorcycle. I went through 2 Garmins before I gave up and bought a used Zumo 550. I'm sure there will be someone that chimes in that they have had theirs mounted for a gazillion miles without problems but that my 2 cts.
I also found that the over the dash mounts are not that stable. OK for the slab but they bounce around too much for much off road work. One of the problems is that the front cowl where the windshield is mounted is not rigidly mounted and bounces around quite a bit and this is what the over the dash mounts are mounted to.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
dravnx is offline
post #6 of 32 Old 01-13-2016, 04:58 PM
Rolex's Avatar
By not having Bluetooth instructions being able to see the screen will play a huge part in your ability to use the GPS, you will spend a lot of time looking at a hard to see screen.
My thoughts are that could me put into a life threatening situation which would make a Zumo a very cheap product.
2014 V2, Snoopy
Rolex is offline
post #7 of 32 Old 01-13-2016, 06:24 PM
Hard miles's Avatar
I have been using a nuvi 14xx on my Vee for a few years. Bought a cradle from GPS city and attached it to the handle bar, more or less covering the speedometer. Vibrations are low, screen easily tilted so it is readable in almost all conditions. It is rendered waterproof by putting a ziplock bag over it when it rains (use electrical tape to keep it place against the wind). A point was raised that the usb connector wants to come out-- after awhile it does... I use a small strip of cloth that I jam into the cradle to keep the connector in place.
The 58LM & 68LM are similar to the 14xx and should work fine. I thought about buying the zumo but too much money for what it's worth.
Also map updating is straight forward using garmin express ( on windows anyway)
Have a good one
Brian
Hard miles is offline
post #8 of 32 Old 01-13-2016, 07:30 PM Thread Starter
Thanks for the replies.
If I'm reading Garmin's information correctly both Garmin Nuvi models (58LM & 68LM) have the "Trip Planner" and 1000 way points. I've never used these but if I understand correctly, I could lay out a route and enter way points.
I have read comments that the SW Motech vibration-dampened mount vibrates. I bought it a year ago so I'm kind of stuck with it. Some say they work good on pavement but not on gravel. Others claim the vibration can be reduced by adjusting the tightness of the rubberized connections. I'll give it a try. If it's useless, well I will have learned a lesson about the manufature and avoid them in the future.
I have Bluetooth in my car and never use it so I do't see that as a viable option.
The power connection is a concern. I'll have to think about that vs a Zumo or Rider unit.
Thanks for the input. I'll keep researching options.
keuka is offline
post #9 of 32 Old 01-13-2016, 08:05 PM
blaustrom's Avatar
When you buy a car GPS one of the most important aspects is how bright it is. Normal car GPS are not very bright and you will not be able to see the information you need when the GPS is in bright sunshine! Since most of us prefer to ride when it's nice, this is a real problem.
I use a 3790LT. It is very bright but has a very reflective screen. By adding an anti reflex screen protector it is still quite bright but not as reflective, so that works in direct sunlight. With a ram mount and all openings of the GPS taped shut, it has served me well. You can rotate it 90*. And it does routes, essential for trip planning. Not as good as a MC GPS but now bought used only a fraction of the price. I have it mounted over the dash on a custom dash shelve. Yes it vibrates but when the going is rough you focus on the road, not the GPS. Once the road is reasonable then there is no problem reading the GPS. And you do it without taking your eyes of the road completely!
As regards the power supply. It uses a regular cigarette lighter plug to USB power supply. That has never come out of the speaker unit that cradles the GPS. But you need a power outlet somewhere close by. I mounted mine underneath the dash/ instrument panel and I have 2 power cords installed, one for my ancient GPS that I use around town and don't bother to take off and the one I use for trips. Those cigarette lighter plugs do want to vibrate out, so if the unit stops looses power, that is likely the problem.
blaustrom is online now
post #10 of 32 Old 01-13-2016, 08:30 PM
2mstone's Avatar
My thoughts are that could me into a life threatening situation which would make a Zumo a very cheap product.
I guess...
I don't live in a large city and avoid them whenever I can, so maybe I don't understand. But I've never felt like looking at my GPS has been a life threatening situation, sunny day or not.
Usually my instructions are numerous miles apart, 18 miles, 70 miles, 200 miles, etc.
"Tombstone"
S-10
My Alaskan Adventure
http://2mbstonestravels.blogspot.com/2015/04/alaska-or-bust.html
2mstone is offline
