Sun Hood for 590LM - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By RCinNC
post #1 of 8 Old 01-02-2016, 06:57 PM Thread Starter
OzCrow's Avatar
Sun Hood for 590LM
Last time i was out riding I thought a hood or sun shield would be great to stop the glare on the screen making it hard to see.
So yesterday I thought I'd make something up.
[IMG][/IMG]
[IMG][/IMG]
OzCrow is offline
post #2 of 8 Old 01-03-2016, 11:38 AM
kbyte255's Avatar
Sweet. How about more info on how you did it, where you got your materials, etc.
2013 XT1200Z Super Tenere'
2005 DL-650 Wee-strom
Last edited by kbyte255; 01-03-2016 at 11:38 AM. Reason: I always make at least one mistake
kbyte255 is offline
post #3 of 8 Old 01-03-2016, 12:56 PM
Some hardware stores sell sheets of rubber in various thicknesses. I made a similar hood for my Garmin for a couple bucks. I velcro'ed it to the GPS.
It do make a difference.
post #4 of 8 Old 01-12-2016, 10:19 PM
It shouldn' Help
The G 590 is the only auto/moto GPS device equipped with a color transreflexive LCD display. The display uses and reflects back into your face direct sunlight, particularly when the Sun is over your shoulder. There are some conditions that cause problems, however. If your going into the Sun and have a safety vest or some other reflective coat, that image will shine onto the G590 and then be reflected back into your face. A hood will not stop it. Another condition is the Sun can be off to the side where its light reflects off the surface of the glass display. This is a very transient condition and even a slight motion of the handle bar might change the angle of reflection. Generally, a hood on a G590 should not help you see the display. Hoods can be effective with all other GPS devices under some conditions but if the Sun is over your shoulder, the hood will have to be very long to do any blocking plus you have to get your eyes way down. IMO there is nothing about the G590 that is not available for less money except the transreflexive display. Google it and read the Wikipedia article.
Wildbill1945 is offline
post #5 of 8 Old 05-09-2016, 04:15 PM
Gingie's Avatar
Nice! Is the Velcro holding up OK? I thought about using a rubber mat too, with grommets and zip ties.
Then the good idea fairy hit me and I decided to use an old deck-screw box. Painted it black, and voila:
Gingie is offline
post #6 of 8 Old 05-10-2016, 04:15 PM
RCinNC's Avatar
There are some good ideas on here. I'll throw mine in too. My sunshield is made from sheet plastic, with nylon webbing hinges so it can store flat when it's not being used. It's attached to the RAM cradle for my Garmin with velcro (the velcro is glued to the cradle with E6000, one of my favorite cements).
RCinNC is offline
post #7 of 8 Old 05-11-2016, 11:11 PM
Gingie's Avatar
how did you attach the webbing hinge to the plastic? E600 as well?
Gingie is offline
post #8 of 8 Old 05-12-2016, 10:08 AM
RCinNC's Avatar
Yep. I glued the webbing to the plastic shield, then put a book on top of it to clamp the pieces together, and let it sit overnight. The bond has held up under repeated flexing of the webbing joint, with no sign or weakening. That E6000 is one of my favorite cements for bonding dissimilar materials.
Gingie likes this.
RCinNC is offline
