Headlight relay - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 1 Post By greywolf
  • 2 Post By PTRider
  • 1 Post By yesbut
post #1 of 8 Old 11-18-2015, 12:54 PM Thread Starter
Talyn's Avatar
Headlight relay
Has anyone re-wired the lights to pull it from the switch being the main source of power??
This is a wiring thing that a lot of companies have done throughout the years by running the power though a lot of wires essentially causing a huge power loss by not putting in a relay.
Big deal with some of the older fords.
The issue with those was the headlights only getting 10ish volts due to how it was wired vs the 12 they should be getting.
Whiter Whites, Brighter Brights - Ford-Trucks.com
This is an article i'm referring too.
It works for the the trucks really well, but I don't think I've seen anything regarding something like this for our bikes.
I'm not 100% sure if our power system could handle giving full output to the lights, but I'm sure that the lights would be waaaay better when getting full voltage vs what they are loosing though the weak starter switch.
This could be wired 2 different ways.
Toggle on the dash, or just still using the stock switch, but the relay in between allowing for the starter switch to negotiate the relay hookup as opposed to a toggle switch.
Thoughts?
Talyn (AKA: der Schafen Führer)
Power Stroke Enthusiast! 1994 F250 T444-E
Need a Vee so I can Squee!
[b]You can get more with a kind word and a 2x4 than you can with just a kind word.[/b]
Talyn is offline
post #2 of 8 Old 11-18-2015, 01:48 PM
I suggest you do some searching here, there's a massive thread somewhere, and commercially available Wee specific relay kits. I've put one in myself.
yesbut is offline
post #3 of 8 Old 11-18-2015, 02:50 PM
This this kit is all plug and play with some options.
VStrom
A couple of relays and a little wiring experience makes a nice DIY project. Use the battery negative for ground from each headlight connector on the lower left though, not the chassis. The #85 relay terminal grounds and the H4 male connector on the upper right can be from black/white stock wires as they only power the relays. Stock high beam wires are yellow and low beam wires are black/blue while ground wires are black/white.
Talyn likes this.
post #4 of 8 Old 11-18-2015, 03:51 PM Thread Starter
Talyn's Avatar
Oh cool
Same concepts.
I love this forum, but there is a slight disconnect on articles sometimes when things are wrote up for a wee and not a vee.
That and the odd differences between the wee and vee.
Like front sprocket nuts, or how the wee has abs and the vee doesn't.
I have a tendency to search forum specific instead of whole forum as i've noticed even at times that torque specs are different between wee and vee.
Thanks for the replies guys!
Talyn is offline
post #5 of 8 Old 11-18-2015, 11:30 PM
I make one change from GW. I run a large gauge negative wire from the battery to the front of the bike to make a negative bus. I connect all my accessory negatives to this. It is the same thing electrically, just a bit easier and neater.
uncaged and ACKMANDO like this.
post #6 of 8 Old 11-18-2015, 11:33 PM
Originally Posted by PTRider View Post
I run a large gauge negative wire from the battery to the front of the bike to make a negative bus. to this.
I prefer nice cheerful positive buses, there's far too much negativity around these days.
Ozarkdave likes this.
yesbut is offline
post #7 of 8 Old 11-19-2015, 01:05 AM
uncaged's Avatar
Eastern Beaver Dude, all will be explained...
uncaged
Sniper, Lover, Thug, Casual Hero, Savior of the Oppressed.
Printed on our business card as a proud member of Delta Company, 82d Combat Aviation Battalion.
2012 DL1000 Yeah Baby!
Scratch Built FXR gone
'07 Honda 919 gone
'07 Suzuki DR 650 gone
'85 Honda Sabre 45 gone
'82 Yamaha XS 650 Special II gone
'73 Honda SL350 gone
'71 Yamaha DT 250 long gone
'65 Honda CB 160 long gone
uncaged is offline
post #8 of 8 Old 11-19-2015, 08:44 AM
Not really a change but a clarification. I've done the same thing. I put a fuse block in the fairing of one bike and ran 12ga positive and negative main wires to the fairing on the other. Each also had positive and negative bus bars on the top of the battery.
