Question for Garmin Geeks - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 08-29-2015, 03:31 PM Thread Starter
i bought a used Nuvi 765 off of EBay a while back. It worked very well, blue toothed just fine to my Sena headset, but the maps were out dated. So I plugged it into my PC with Garmin Map Manager and downloaded new maps with no issues (I had and SD card plugged into as well). Tried it out on a ride today and had an issue; on secondary roads the moving map showing the road I was riding would disappear, but it knew where it was because the correct road name would be displayed at the top of the screen. When I approached or turned on to major roads everything would work fine. Any ideas??
TCinNC is offline
post #2 of 19 Old 08-29-2015, 03:40 PM
I suspect you mean that the road stops showing rather than the moving map disappears.
There is a setting to control the level of map detail. You want more (or maybe maximum) detail.
Trepidator is offline
post #3 of 19 Old 08-29-2015, 03:41 PM
I've had that happen when a roadway was moved and the map had it in the old place. Was the road new?
post #4 of 19 Old 08-29-2015, 03:46 PM Thread Starter
Yes, you are correct, the road stops showing. I tried the Max setting on map detail, no difference.
TCinNC is offline
post #5 of 19 Old 08-29-2015, 03:48 PM Thread Starter
Grey wolf, no the road wasn't new. I have traveled the road many times, no problems with the old map. Today the road disappeared, as did other old secondary roads I was riding.
TCinNC is offline
post #6 of 19 Old 08-29-2015, 04:30 PM
Are you sure the area you were in was covered by the map update? Typically, you select what parts of the country you want to include in an update. Older units especially don't have enough memory to handle the entire country. To use an SD card for maps, I had to override the stock settings and download the new map to my computer. Then I had to download the map from the computer to the SD card.
It sounds like you only have the base map that just shows Interstates and national highways and don't have the detail map loaded for your area.
post #7 of 19 Old 08-29-2015, 05:13 PM
RCinNC's Avatar
I experienced this same thing with a Garmin Nuvi 2455 just the other day. It happened right after I did a map update. Don't know if there is a correlation or not. It wasn't a major road that disappeared.
RCinNC is offline
post #8 of 19 Old 08-29-2015, 09:59 PM Thread Starter
Greywolf I think you might be on to something. I need to go back into my Garmin Map Manager on the PC and try to figure out what happened in the download process for the new maps. I do recall the program recognizing there was an SD card in the Garmin. I just assumed the maps got installed there.
TCinNC is offline
post #9 of 19 Old 08-29-2015, 10:00 PM Thread Starter
So what did you do to try and correct it?
TCinNC is offline
post #10 of 19 Old 08-29-2015, 11:19 PM
I have had Garmin GPS units start showing incorrect map detail while still appearing to navigate correctly. I cured it with a hard reset. If I recall, I had to power the unit on while touching the upper left corner of the screen. A question came up on the screen asking if I wanted to erase all data. After the unit restarted all my tracks and prefs were gone, but everything worked correctly again. Check Google to see if the procedure is the same for yours.
brucen is offline
