Plug and play power for smartphone? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 08-16-2015, 11:40 AM Thread Starter
everready's Avatar
I'm seriously thinking of going the smart phone route and using offline maps via Locus. Is there a plug and play power cord for a smart phone that will hook directly into the accessory plug on a 2013 Vstrom?
Thanks,
Al
P.S. I know these questions get asked a lot and I have done some searching but asking folks who KNOW is reassuring.
2013 DL650A "Blue"
Previous bikes: '78 CB750F, '86 Nighthawk S, '87 EX500, '85 Sabre 700, '93 Katana 600, '75 Rupp 80, '78 DT250, '88 TT225, '89 CR250
everready is offline
post #2 of 14 Old 08-16-2015, 11:57 AM
The aux connector in the right side of the fairing is designed to handle such a task.
https://www.stromtrooper.com/dl650a-2...-location.html
post #3 of 14 Old 08-16-2015, 12:16 PM Thread Starter
everready's Avatar
Yes sir. I plan to use the accessory outlet. I'm wondering if there is a USB power cord for a smartphone that'll just plug right into the accessory plug.
2013 DL650A "Blue"
post #4 of 14 Old 08-16-2015, 01:27 PM
Stromtrooper.com Sponsor
Satch's Avatar
I connected a SAE connector to the aux power connector on the right side and ran it into my tank bag. I attached a Battery Tender USB adapter to the SAE connector. It has a 2.1 amp output which works great for charging both my iPhone 6 and iPad. I'll try to post pics.
Edit: It's this:
Connected to this:
I had a spare Battery Tender pigtail that is normally used to connect the BT battery charger directly to the battery. I cut off the terminal rings and put on the connectors that I got from EB to plug directly into the aux power connector on the right side of the fairing. I also put in a 3 amp fuse.
:arrow: Follow the V-Strom Cache Adventure | See Where the Cache has Been | Play the Stromtrooper Picture Game | Play the Weekly Picture Game
Preferred V-Strom Model Nicknames: 02-12 DL1000 Vee, 2014+ DL1000 ABS Vee2, 04-11 DL650 Wee, 12-16 DL650 Wee2, 17+ DL650 Wee3
V-Stroms I've owned: Wee.07, Wee.11, Wee2.13. Currently Wee-less
Satch is offline
post #5 of 14 Old 08-16-2015, 01:42 PM
That connector is what Suzuki uses for accessory power port. The connector is a 2 Pole .090 WP MT Connector 'Special B'. I don't know of any direct to phone cable. Eastern Beaver makes a connector to fit.
See VStrom
It alone doesn't meet the $20 minimum order though. It's always a good ides to add headlight relays and they will make the minimum. Otherwise, do a search on the connector for a lower price. you will still need to get a female USB connector including a 12VDC to 5VDC regulator to wire in. Probably the easiest way is to get a USB power cable with regulator and wire it into the MT connector. Bear in mind it is a polarized connection.
Those terrified of wiring can get the Suzuki power outlet at 12V Power Outlet:|| Suzuki Motor of America, Inc and plug a USB port like this into it. It has a regulator built in. Even then, things may like to vibrate out. You may be able to entice Jim Davis at Eastern Beaver to make an MT to USB female cord with regulator.
post #6 of 14 Old 08-16-2015, 02:52 PM
gn83tm's Avatar
I use this unit, that I got here: Amazon.com: EDO Tech® Micro USB Direct Hardwire Charger Cable Kit for Car Vehicle Motorcycle Bike: Cell Phones & Accessories It's wired to my power strip under the seat.
2008 Suzuki Wee Strom
2006 Honda 919 Hornet
2003 Kawasaki KX200
gn83tm is offline
post #7 of 14 Old 08-16-2015, 02:57 PM
Notice the box in the wire. That's a 12VDC-5VDC voltage regulator. I forget about that in my previous description so just added it.
post #8 of 14 Old 08-16-2015, 03:14 PM Thread Starter
everready's Avatar
Originally Posted by gn83tm View Post
That could be wired directly to the battery then?
Thanks,
Al
2013 DL650A "Blue"
post #9 of 14 Old 08-16-2015, 04:48 PM
Macdoc's Avatar
So far been happy with the price and use of the this
https://www.amazon.com/gp/your-accou...140_TE_SIMP_on
Not sure of durability but does the job and gives me options to charge more than one thing at a time.
This being the prime one.
HOME • Antigravity BatteriesAntigravity Batteries | Lithium Ion Motorcycle Batteries
Should be in EVERY touring riders kit. On our 3 week west coast trip we had it in use ALL the time - the only thing we did not do is start the bike with it.
The other good thing for the iPhone is this
mophie Battery Phone Cases & More - Free Shipping | mophie
Gives an X-grip a bit more purchase and doubles or triples battery life.
Canada 2018 CB500x >2009 CBF1000 sold 10 Wee ABS sold09 Burgman Exec sold • 10 NT700v sold
Australia> 04 KLR65093 ST1100 sold
Macdoc is online now
post #10 of 14 Old 08-16-2015, 06:31 PM
gn83tm's Avatar
Thanks,
Al
It could be, but it might draw a little power even when nothing's plugged in. I have it on switched power (a relay turns the fuse block on and off with the ignition).
2003 Kawasaki KX200
gn83tm is offline
