Garmin GPS Bluetooth Turn by turn Voice directions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 06-18-2015, 11:01 AM Thread Starter
rkruz's Avatar
I understand some Garmins, while having Bluetooth, do not provide Voice turn directions over a BT headset. Would you know which automobile Garmins (not the expensive motorcycle units) provide voice turn by turn directions for a headset.....use SENA 20S as an example?
thanks!
DL1000 2012
rkruz is offline
post #2 of 17 Old 06-18-2015, 11:27 AM
I have a Garmin Nuvi 765 that gives voice directions to my Sena SMH 10. You can find them on eBAY, that's where I got mine.
TCinNC is offline
post #3 of 17 Old 06-18-2015, 12:00 PM
I've been in the market for something like this as well. The new ones don't broadcast. If you do a google search, you will find a list that garmin has somewhere on their website of which units broadcast to Bluetooth devices. The other things I've seen people do is mod a newer one (as some can be found cheaper than the older ones that broadcast to headset) with a Bluetooth dongle that will then broadcast the sound.
bsevans5 is offline
post #4 of 17 Old 06-18-2015, 01:26 PM Thread Starter
rkruz's Avatar
good input. Ive found while the Garmins will not Bluetooth capability, this is only for phone interface and will not transmit directions to a headset.
rkruz is offline
post #5 of 17 Old 06-19-2015, 09:23 AM
JackinCT's Avatar
Same model I have. Works great for turn by turn and has a built in music player.
JackinCT is offline
post #6 of 17 Old 06-19-2015, 08:53 PM
Rolex's Avatar
Does it have to be Garmin ?
I found many Tomtom's and Navman's will work with your head set.
I took my head set to a local store and had a play with the new models on display.
I found all the ones that worked with my head set then made a choice.
It was to be used in a car but I thought I should get one that could be a back up for my Zumo.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #7 of 17 Old 06-20-2015, 08:07 PM Thread Starter
rkruz's Avatar
Thanks for the tips. Ill look into the other GPS some more.
DL1000 2012
rkruz is offline
post #8 of 17 Old 06-30-2015, 10:27 PM Thread Starter
rkruz's Avatar
Does the 765 provide "active logs" or the a gpx of the actual route traveled? with 855 model I have been using i can use Basecamp and "recieve from device" to obtain the active logs. this only be done if you remove the battery and replace it then the active log is available.
I did get a 765 and dont seem to be able to obtain a active log. Do you also have to remove the battery from it to get the active log?
DL1000 2012
rkruz is offline
post #9 of 17 Old 06-30-2015, 11:23 PM Thread Starter
rkruz's Avatar
Is there a trick to pair the 765 to Sena? I cannot pair with the Sena 20s. I keep getting a failed message from the 765.
DL1000 2012
rkruz is offline
post #10 of 17 Old 07-01-2015, 12:50 AM
drrod's Avatar
I wonder if the newer firmware updates have something to do with this. I used to be able to pair my TomTom 920 with my Sena SMH10 but now it won't. I haven't really dug into this yet but I have my suspicions.
Rod
drrod is offline
