Voltmeter and temp gauge - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 06-03-2015, 09:22 PM Thread Starter
finished installing my new gauges tonight. Volt meter on the left and ambient temp on the right. They are similar to the datel voltmeter. I didn't like the idea of cutting two big square holes in the plastic so I made small frames from aluminum angle and bolted them on beneath the gauges. I have the temp sensor stubbed out of the little triangle grille just below the headlight. Turned out pretty good, I think. Easy to see but still unobtrusive.
Painted the frames and screw heads with black nail polish. The pretty much disappear.
Convict1997 is offline
post #2 of 10 Old 06-03-2015, 09:34 PM
newhoco's Avatar
Nice ! Where did you source the displays ?
Alex .
Not all my lucid moments are consecutive .
newhoco is offline
post #3 of 10 Old 06-03-2015, 10:13 PM Thread Starter
Cyclemax.com. $23 for the voltmeter. $15 for the temp.
Mini LED Digital Voltmeter
Mini LED Digital Thermometer
post #4 of 10 Old 06-05-2015, 02:09 AM
Rug Emporium's Avatar
I have the same temp and volt meters mounted on the underside of a pat walsh dash
Rug Emporium is offline
post #5 of 10 Old 06-05-2015, 10:46 AM
Neat-o farkles!
post #6 of 10 Old 06-12-2015, 06:43 AM
2wheelrob's Avatar
Been thinking of a voltage meter but was wondering how/where they wire in. I am not schooled in wiring so unless something has very easy instructions, I get concerned that I will end up hurting a component that is much more expensive to replace.
2wheelrob is offline
post #7 of 10 Old 06-12-2015, 06:52 AM
Sgt Schultz's Avatar
I just ran the two wires back to my fuze block, one neg, the other pos. The pos is on the switched connector in the fuze block. Only comes on when ignition is on.
Or just put them on the battery terminals but then will be on all the time.
I know nuffink, I see nuffink, It was not me, I was not here.
IBA #45920
FarRider #299
2015 Wee Strom "Piglet"
Givi crash bars, Barkbusters, Ravetech Bash plate, Ravetech Rad guard, Ravetech over dash Ram mount, Hyperlite flashing brake lights, Madstad bracket and screen, Augustus wind deflectors, Spot 3, UHF two way radio, Garmin Zumo GPS, Starcom intercom, Fuze block.
SW Motech Centre stand, Suzuki power outlet. Bike Alarm, Screaming Banshee horn, Led Flood lights, Tool tube, Andy Strapz Expedition soft panniers and frames.
Sgt Schultz is offline
post #8 of 10 Old 06-12-2015, 07:13 AM Thread Starter
Same here. Wired positive to one of the switched leads on my fuse block and negative to my ground block. If you don't have a fuse block, you could just tap the positive wire into a switched wire on the bike. I used the tail light for the switched wire to trigger the relay for my fuse block. I'm sure there is a wire up front you could use, too.
post #9 of 10 Old 06-13-2015, 10:31 PM
Mexicant's Avatar
image.jpgI got the 12v plug in one but it reads Celcius. Only used it in the car as I haven't yet out a 12v outlet on the Strom's.
Mexicant is offline
post #10 of 10 Old 06-13-2015, 10:34 PM
Mexicant's Avatar
This might work as well but not sure if you could make it waterproof enough.
Mexicant is offline
