Zumo audio problems - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 07-03-2008, 03:14 PM Thread Starter
Zumo audio problems
I've been having mini dropouts in the audio for a while. High rpms, pushing or twisting the plug, resetting the unit and just about anything else I tried would change the quality of the sound. It turned out the cradle was not making good contact. Any movement of the unit in the cradle would affect the sound. If anybody is having audio droput/static problems, try wiggling the unit in the cradle. If that affects the sound, the cradle needs to be replaced.
post #2 of 7 Old 07-03-2008, 04:05 PM
tmcgee's Avatar
Use a good contact cleaner on the cradle pins and work it in with your finger before wiping it off. A new cradle is only going to delay the inevitable. It's a crappy design. I use Caig D5.
tmcgee is offline
post #3 of 7 Old 07-03-2008, 04:10 PM Thread Starter
Contact cleaner didn't do it. I think the springs on the pins get sacked.
post #4 of 7 Old 07-03-2008, 04:25 PM
tmcgee's Avatar
I had to give mine a good bath with the cleaner the first time. Now I hit it about every three weeks. Audio problems aren't the only contact problems. Power up/down, loss of GXM antenna, and a few others have hit me as well.
One other thing to check is the weather gasket around the contact pads on the bottom of the Zumo. It can drift and cover the pads.
tmcgee is offline
post #5 of 7 Old 07-03-2008, 05:50 PM
Heavy's Avatar
Good stuff to know guys....Thanks!
DL1000K6
Heavy is offline
post #6 of 7 Old 07-03-2008, 08:44 PM
ElBando's Avatar
I use a pencil eraser to clean my contacts and apply some dielectric grease around the base of the unit before I snap it in place. I used to have distorted audio on MP3s and the Navi voice but not anymore.
2007 DL650 ABS ( she thinks it's hers, but it's MINE )
2006 GL1800 ABS ( ours )
2001 VLX600 ( spare )
2000 4X4 Rancher ( his )
2000 4X4 Rancher ( hers )
1991 XL250R ( hers )
1983 XR250L ( his )
1974 CB360 ( retired )
All from the same people who
brought to you "PEARL HARBOR"
Patriot Guard Rider
AMA Member
U.S. Navy Veteran
ElBando is offline
post #7 of 7 Old 07-03-2008, 09:04 PM
tmcgee's Avatar
The bad connections are internal to the mount. The contact pins that stick up from the base are spring loaded. The intermittent connections are the result of the spring not making good contact with the pins and/or the spring not making good contact with the underlying circuit board/circuitry. There are TWO points inside the cradle that are failure prone.
As I said, it's a crappy design for something that has to be out in the weather. I would have preferred a hard-wired connecting cable.
If I ever get inspired, I'll open up the cradle and hard-wire each pin to it's circuit board pad.
tmcgee is offline
