Autocom install report - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 06-30-2008, 10:08 PM Thread Starter
randyo's Avatar
finally a moment to intall the Autocom I bought a few weeks ago
took longer than expected
mostly sorting out the cables so that I could run everything neatly
first, because of noise reports when installed under the seat, I fashioned a 4 sided box (no front or top) out of some lead flashing I had laying around, I mounted the unit in the rear of the front underseat compartment (my scottoiler is in the rearward compartment) that left me with room to coil the unused pillon lead
my power source is a 6 place fuse panel & hella micro relays
input # is connected to the bluetooth adaptor that I have velocroed inside hte faring # 2 is connected to my Zumo450 #3 is empty # 4 is connected to my V-1 and the bike to bike lead is connected to an ICOM style input at the handlebar for connecting either ot my Midland 75-822 CB or my RadioShack FRS unit
I also installed a PTT switch, had to slide there clutch perch & mirror about 3/8" inward to squeeze it between the perch and control pod
all my wireing comes together at a point just below the left side of my handlebar into 36" of 3/4" split seam conduit where is runs down above the left frame rail, under the tank mounting bracket then to the right side of my battery, a couple of cables have excess loops and the isolators resting just behine the battery before they run thru the firewall into the compartment space
took me a few hours and a few dubes to figger it out, in the end, every thing is neat and tucked into it's space
so far so good, been listening to mp3s on my zumo, directions & radar override the music, havent tried 2 way yet (need someone on other end)
no problems pairing my Nextel to the bluetooth,
now I can talk when someone form the office called me rather than attempt morse code but squeezing the noise I hear in my pocket
sound quality is even better than I expected, some slight noise (crackling) when I first grab a handfull of throttle in the lower gears, not rpm related, it's only momentary in 1st & 2nd, but not when I roll on the throttle, only under hard acceleration for a split second, it's not bothersome, when I'm twisting the throttle that hard who cares, and it goes away in less than 2 seconds
maybe I can post some pictures tomorrow
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #2 of 9 Old 07-01-2008, 07:07 AM
tmcgee's Avatar
The crackling isn't normal, Randy. Sparkplug noise maybe. Try dressing the cables another way, or even turning the control box upside down, on edge, sideways, etc. The cover plate is cast aluminum, but most of the box is plastic.
tmcgee is offline
post #3 of 9 Old 07-01-2008, 08:35 AM Thread Starter
randyo's Avatar
doesn't sound like any spark plug noise i ever heard.... no room to move twist location, a couple of cables are just barely long enuf, but I might try making a lead flashing cover
the only time I hear the crackle is near full throttle acceleration for just a split second and only 1st or 2nd, I thought it might be the RR when it first gets a whoppin power increase from the stator that's makin the noise
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #4 of 9 Old 07-01-2008, 11:50 AM
V-Tom's Avatar
Isn't crackling a sign of a bad connection somewhere?
The only time I have experienced crackling is when the leads in my helmet were not clicked together properly. Maybe the acceleration is moving the wires to the helmet and causing a bit of pulling on the wires inside?
I might also suggest checking that all the other connections (power, to radio, etc) are not loose.
..Tom
SMIDSY detailed report.
V-Tom is online now
post #5 of 9 Old 07-01-2008, 07:21 PM
CrozB's Avatar
Good Job! Looking to get Bike to Bike of some sort myself and Autocom is in the top line of consideration.
Look forward to seeing the mounting pictures when you have time.
-D
[COLOR=darkorange][B][SIZE=2][FONT=Verdana][URL="http://www.CrozB.com"][SIGPIC][/SIGPIC][/URL][/FONT][/SIZE][/B][/COLOR]
[FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=2][B]In the Garage: [/B][/SIZE][/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=2][COLOR=white]-----[/COLOR]'07 V-Strom 1000 (Blue) [URL="http://www.crozb.com/bike"][COLOR=#800080]Farkle List[/COLOR][/URL][/SIZE][/FONT]
[SIZE=2][FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=2][COLOR=white]-----[/COLOR]'07 Can-Am Spyder (Silver) [/SIZE][/FONT][/FONT][/SIZE]
[FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=2][COLOR=#800080][URL="http://www.crozb.com/outdoors"]Ride Reports[/URL][COLOR=white] --------------------[/COLOR][URL="http://www.CrozB.com"]www.CrozB.com[/URL][/COLOR][/SIZE][/FONT]
CrozB is offline
post #6 of 9 Old 07-01-2008, 10:19 PM Thread Starter
randyo's Avatar
crackling is gone, after I fine tuned the VOX adjustment and played with the positioning of the noise sensor
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #7 of 9 Old 07-02-2008, 11:02 AM
autocom installation
Have you used the midland cb yet, I have never been able to get one to work, always have to use the cobra road trip & do a buch of other tricks to make that cb work. Kieth in Tulsa,
Kieth is offline
post #8 of 9 Old 07-02-2008, 05:10 PM Thread Starter
randyo's Avatar
Pics as promised
#1 full view of underseat
#1 Valentine 1 on right side of handlebar
#3 PTT switch, left side cluster
#4 forward compartment with Autocom, fuseblock # hella micro relays
#5 Scottoiler in rear compartment
#6 Ground buss on front of forward compartment
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #9 of 9 Old 03-17-2010, 07:11 PM
2tall's Avatar
An old thread I realize, but did you get the Midland CB radio to work with the Autocom?
John
johnvstrom at yahoo.ca.............. V-Stromming since '03
'06 DL1000 Grey
'03 DRZ400$ sold, down to one bike
2tall is offline
