Garmin 2610 Mounting ?'s - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 06-16-2008, 06:57 PM Thread Starter
Hello All:
I recently purchased a Garmin kit from another rider. It has the Garmin cradle, and hardwire cable. The cable has a red fused hotwire and black ground, in addition to a white cable and a brown cable... Any ideas what these are for?
It looks like most of the RAM kits come with a cradle that use a diamond-shaped, 2-hole mounting, system... the Garmin cradle uses a square 4-hole pattern. Any ideas what bracket I need?
Also, any sources for a handle-bar kit that doesn't include the cradle?
I had planned on using the U-shaped bolt and mounting to the handlebars, but I'm intrigued with the option if drilling and tapping my bar riser and installing a 1" ball with the 1/4 x 20 threads. Has anyone done this, and how did it work out?
Thanks for any advice.
2Gordons
2Gordons is offline
post #2 of 7 Old 06-16-2008, 07:18 PM
jmz
jmz's Avatar
I think those other wires are for a speaker. I have been doing some research as I want to put a 2610 on my bike.
2012 Super Tenere
2014 KTM 500 XCW plated
2000 KTM 380 EXC plated. for sale
jmz is offline
post #3 of 7 Old 06-16-2008, 08:10 PM
SCraig's Avatar
Techmount #30996 available from Cycle Gadgets.
Scott Craig - Nashville, TN
SCraig is offline
post #4 of 7 Old 06-16-2008, 08:16 PM
GRS1959's Avatar
Send a message via AIM to GRS1959 Send a message via Yahoo to GRS1959
A fellow board member pointed me to this site. Looks like they have anything you would need to mount your 2610.
http://gpsnow.com/gmsp2610acc.htm
- Gary
Be Ashamed to Die Until You Have Won Some Victory for Humanity. ~Horace Mann
Red DL650K6
GRS1959 is offline
post #5 of 7 Old 06-19-2008, 06:47 PM Thread Starter
Perfect. Thanks!
2G
2Gordons is offline
post #6 of 7 Old 06-19-2008, 07:49 PM
GRS1959's Avatar
I just snagged a factory refurbished 2720 on eBay. Unfortunately, the RAM mount is backordered on that site I linked to, and had to look for other options. The cheapest place I found mounting hardware was actually at Amazon.
- Gary
Red DL650K6
GRS1959 is offline
post #7 of 7 Old 06-19-2008, 10:46 PM
You'll find that the diamond shaped RAM mount will also fit two of the diagonal holes of the 4-hole pattern on your Garmin mount.
Jamie
Jamie Z is offline
