Voltage meter wiring - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 06-04-2008, 06:22 PM Thread Starter
OK after readng all the threads about voltage metering I decided it is something I need to do. When wiring in the meter is it all right to connect it to my switched Blue Seas or do I need to take it directly to the battery?
07 650 ABS
76 Bonneville
twistnh is offline
post #2 of 6 Old 06-04-2008, 06:43 PM
SVDon's Avatar
Depends on whether or not you want the voltage meter to be on all the time or just on when the bike is on.
Most people just tap it in to a handy accessory wire, headlight wire, or most any switched wire not in the ignition system. No need to run a separate wire back to your fuse panel (assuming your fuse panel is in the back someplace) but that'll work too if you want to. Mine's tapped into the hot wire that goes to my powerlet outlets.
Don F.
Smith, Nevada, In view of the High Sierra
DL650 K4
DL1000 K5
Keeper of the ST1100 liST [url]www.st-riders.net[/url]
[url]www.quilt-kits-online.com[/url] for great quilt kits and supplies, outstanding customer service.
SVDon is offline
post #3 of 6 Old 06-04-2008, 07:42 PM
roger123's Avatar
I have mine connected to the factory heated grip connection (along with my heated grips).
Roger ('14 Tenere ES, COG 5903)
roger123 is offline
post #4 of 6 Old 06-04-2008, 07:44 PM Thread Starter
By wiring the volage meter to a switched source will it be monitoring the "system" voltage and not just the voltage from that one switched device? As you can tell I am not an electrical type.
07 650 ABS
76 Bonneville
twistnh is offline
post #5 of 6 Old 06-04-2008, 08:40 PM
Koinz's Avatar
"Switched" means that it turns off with the ignition. When your engine is running or the key is turn on, you will "see" what the battery "sees" whether it's charging or not.
Probably better to be on a switched circuit. There's no need to drain your battery with stuff that's always powered. (except a GPS, mine is hot all the time).
Koinz is offline
post #6 of 6 Old 06-11-2008, 09:49 AM
MZBuckeye's Avatar
I have mine wired to the Blue Sea fuse block under my seat.
1997 Kawasaki ZG1000 Concours, [COLOR="DarkGreen"]GREEN[/COLOR]
Old bikes:
2001 Kawasaki ZRX1200R, [COLOR="Lime"]GREEN[/COLOR], sold
2005 HD FXDCI, sold
2003 Yamaha FZ1, "Bee", sold
2005 Suzuki DL1000, Black, sold
2002 Yamaha FZ1, Silver, sold
1991 Kawasaki Ninja ZX-6D, sold
1982 Honda Sabre 750 V45, sold
MZBuckeye is offline
