Electrical Grounding to the frame...... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 06-04-2008, 02:24 PM Thread Starter
Xavier6162's Avatar
What difference does it make by either sending all electrical grounding wires to the battery negative post as oppose to grounding them to the frame?
Xavier6162 is offline
post #2 of 13 Old 06-04-2008, 02:34 PM
SCraig's Avatar
Grounding copper wires through aluminum can cause a galvanic reaction that can weaken the aluminum. Usually not a good idea for stress members such as a motorcycle frame.
Scott Craig - Nashville, TN
SCraig is offline
post #3 of 13 Old 06-04-2008, 03:03 PM
SVDon's Avatar
I've heard this stated before, and it always brings up two questions in my mind:
a) Has anyone ever had a frame member failure where this was proven to be the cause?
b) A lot of main electrical cables, especially main feeder lines in homes are aluminum wire. Why isn't this considered a problem there, since they attach to copper members, such as the terminals in breaker boxes?
Don F.
Smith, Nevada, In view of the High Sierra
DL650 K4
DL1000 K5
Keeper of the ST1100 liST [url]www.st-riders.net[/url]
[url]www.quilt-kits-online.com[/url] for great quilt kits and supplies, outstanding customer service.
SVDon is offline
post #4 of 13 Old 06-04-2008, 03:10 PM
randyo's Avatar
simplest method of grounding stuff on a bike it to run 1 wire from the negative terminal to the battery to a ground buss,
I have mine located on the front of the trunk space under the seat
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #5 of 13 Old 06-04-2008, 03:46 PM
tmcgee's Avatar
As a trained electronic tech, frame grounding is one of those things that has always weirded me out about automotive wiring. I mean, if it's supposed to be a door panel, floor pan, front bumper or whatever, why would you want to have all those points tied to one of the battery terminals? Is it supposed to save money on wiring or what? Practically speaking, on cars I've owned, a lot of fuses got blown when wires came adrift and grounded themselves by mistake.
The galvanic action argument between copper and aluminum has some merit. Automobile connections used to fail when body panels rotted out.
I think the real reason for running separate power and ground leads has to do with correcting a system that was just plain wrong in the first place, however, since computers are now part of these bikes, having the ability to precisely control where signals and power flow is a very good idea.
This is speculation, mind you, but as a life-long tech, it just made fundamental sense to me when I discovered the Vstrom was wired the way it is.
tmcgee is offline
post #6 of 13 Old 06-04-2008, 03:52 PM
SVDon's Avatar
Since most of my farkles are on the front of the bike, I just run a 10 gauge wire from the battery neg to the front of the bike somewhere, then attach a half-dozen or so short pieces of thinner wire, like 14 gauge to that wire. Crimp on (and solder if you're anal) a male bullet connector to each short piece of wire, weather-proof the connections, and you've got a grounding buss (I call it a grounding spider) ready to go for whenever you need a new ground.
When you add a new farkle just cut the supplied ground wire to length, slap on a female bullet connector, and plug it in. Cheap and relatively foolproof. Also, if one of your farkles starts acting up you know where the ground is.
Don F.
DL650 K4
DL1000 K5
SVDon is offline
post #7 of 13 Old 06-04-2008, 04:39 PM
V-Tom's Avatar
When I used to sell Audi's much was made of the possible reaction when connecting Aluminum body panels to steel parts; in particular in the presence of water and salt. I don't think the aluminum part will fail so much as the connection can be very susceptible to corrosion which can then in the long run cause failures.
I sell Porsche's now, which use a lot of Aluminum, and I don't seem to hear as much about these issues.
As far as aluminum wiring, was there not a lot of concerns with potential fires as a result of the same corrosion when connecting to non-aluminum metals?
..Tom
[QUOTE=SVDon;245105]
[QUOTE]
SMIDSY detailed report.
V-Tom is online now
post #8 of 13 Old 06-04-2008, 04:51 PM
tmcgee's Avatar
Fixtures that take either Al or Cu wiring have been in use for decades. In the old days they used to sell a paste called Noalox for terminals that weren't the Al/Cu type.
tmcgee is offline
post #9 of 13 Old 06-09-2008, 11:35 PM
Put the grounds in a crimp on eye and be done with it. They're steel, and cheap. No worries about possible galvanic corrosion on your frame...which would take a very long time before it affected any structural integrity.
"They will find the streets are guarded by United States Marines!"
2007 Vee with two round black things and a neat thingy on the right that makes it go faster!
cwadej is offline
post #10 of 13 Old 06-30-2008, 06:46 PM
For Audio Equipment grounding to the frame is a bad idea, spurrious ignition noises, alternator whine etc can be picked up by the big antenna (frame) you also never know where the problem is when checking out a problem. If you ground back to the battery you always know where to look. When I wire a bike for audio equipment I keep the circuits seperate, route one power cable and ground to the front of the bike, attach this to a terminal block with 4 + 4- terminals, then secure all wiring to accessories via the terminal block and crimped and soldered lug type terminals. things do not come loose and if one has a problem you know where to look for the problem. If I do have ignition noise in the system I first try to isolate it by disconnecting one audio device at a time. If this does not eliminate the problem I will change the type of wire from 12 gauge unshielded to coax cable using the interior copper wire only for + and a seperate coax cable for the _. If this does not quiet things down I then add a noise filter.
Kieth is offline
Tags
grounding to frame
