Garmin Zumo - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 05-20-2008, 04:19 PM Thread Starter
Garmin Zumo
I used my Zumo on along trip this past weekend and found that the MP3 capacity is lacking.
Can the SD card slot be used to play music?
If so, how to access?
Let the Ride Decide
Let Logic Rule Your Riding
When it Rains I Soar
Rain Rider is offline
post #2 of 11 Old 05-20-2008, 04:30 PM
Yep, my music only resides on the SD card. Zumo will recognize your music on the card automatically.
TM
Rubicon is offline
post #3 of 11 Old 05-20-2008, 05:11 PM
There is a limit of 1000 songs. My 4Gb SD card has close to 800 on it and it takes close to 10 minutes for the unit to start navigating if I use that card. A 2Gb card with close to 500 titles only takes a few seconds so there's either card speed or a non-linear function involved.
post #4 of 11 Old 05-20-2008, 06:15 PM
ElBando's Avatar
I have a ZUMO 450. I store my music on an SD card. Garmin told me that 4 Gigs is the limit for a card. Also in the beginning I was having a problem loading all my mp3s onto the SD card. First you have to make a folder( name it MP3s ) then load to that folder, not just to the card at random. To you young computer guys that may seem a no-brainer, but it took this 59 year old a minute to get that right.
2007 DL650 ABS ( she thinks it's hers, but it's MINE )
2006 GL1800 ABS ( ours )
2001 VLX600 ( spare )
2000 4X4 Rancher ( his )
2000 4X4 Rancher ( hers )
1991 XL250R ( hers )
1983 XR250L ( his )
1974 CB360 ( retired )
All from the same people who
brought to you "PEARL HARBOR"
Patriot Guard Rider
AMA Member
U.S. Navy Veteran
ElBando is offline
post #5 of 11 Old 05-20-2008, 07:09 PM
Heavy's Avatar
I have 2 x 2Gb cards. Lots of music per card but I can swap them if/when I need a change. Loads fine for me.
DL1000K6
Heavy is offline
post #6 of 11 Old 05-20-2008, 07:44 PM
tmcgee's Avatar
I haven't done anything but drag the music files directly to the card, and even iTunes will let you do this from the main window (there seems to be an iTunes restriction of about 100 files at a time).
On the other hand, there is an internal MP3 folder on the Zumo that is unrelated to the SD card.
tmcgee is offline
post #7 of 11 Old 05-20-2008, 07:50 PM
ElBando's Avatar
When I first started to load mp3s on my SD card the card showed the mp3s were on it but the ZUMO wouldn't display them. That's when I called Garmin and they advised me to make a folder. ??? Maybe the 450 is different or maybe Garmin changed it's software....or maybe it's just me...LOL.
1983 XR250L ( his )
Patriot Guard Rider
AMA Member
U.S. Navy Veteran
ElBando is offline
post #8 of 11 Old 05-21-2008, 09:28 AM Thread Starter
On the other hand, there is an internal MP3 folder on the Zumo that is unrelated to the SD card.[/QUOTE]
My tunes are on the internal memory, but I also have an SD card in there. The unit won't access the songs on the SD card. Only access to the internal songs.
I don't understand?
Let the Ride Decide
post #9 of 11 Old 05-21-2008, 09:34 AM
http://www.zumoforums.com/ is a good resource for Zumo info.
post #10 of 11 Old 05-21-2008, 10:43 AM Thread Starter
The MP3 will not work without the SD card in.
If I put blank card in the internal music plays.
Conversly, when I pull the empty card out the internal music stops.
Weird or what?
Let the Ride Decide
