Bought a zumo 550 & Centech AP 1 today. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 05-05-2008, 09:41 PM Thread Starter
Getting ready for a trip to Alaska on June 12. I figure about 10,000 miles before its all done. Going to try to do it in 3 weeks but will probably take a month. The Centech was expensive but it is a nice fuseblock. Got the Centech relay also. Both are very small and can fit anywhere.
Red '05 DL 650.
revel22 is offline
post #2 of 2 Old 05-06-2008, 02:08 AM
BDragon's Avatar
Nice. What tires are you gonna use? Do you expect to change them or will they last you're entire trip? Also be sure to update your zumo. There's an issue that occurs rarely. When it shuts off it won't come back on. All you have to do is reset the system ( remove the battery and put it back.) You don't want to be half way through your trip and not know how to fix it......Yes it happened to me.
Givi Windscreen, Madstads, E21 & E41 Panniers, E52 Top Case, Scorpion Stainless Exhaust, Famsa Tank Bag & Panniers, Symtec heated Grips w/ Grip Puppies, Pat Walsh Engine Guard / Skid Plate, OEM Handgaurds, OEM Center Stand, SWMotech Mirror Wideners, Metzler Tourance, 4" ABS Tube, AutoCom Pro 7, GIPro, Sargent Seat, BSS Fuse Block & Relay, Garmin Zumo 550, Stebel Air Horn, Aux Powerlets, Alaskan Leather, PIAA xtreme white, Superbrace, ToolTube, Kaoko Throttle Control, Highway Pegs, Risers (1" up 1" back) Sonic Springs, 1" raising links, PIAA 510 ATP, Touratech LED Tail Light, Touratech Zumo mount.
BDragon is offline
