Wiring Help - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 11-28-2014, 01:58 PM Thread Starter
Wiring Help
I have a question regarding the wiring harness that came with a set of aux. lights I am trying to install.
The attached is a picture of the wiring diagram. My issue is that is for a direct connection to the battery with a tap off the switch (green wire) going to a switched circuit on the bike.
However I have a switched PC8 already and would prefer to run the lights into it and not direct to the battery. How do I go about changing the circuit to do so? Is it just a case of running the green wire into the red positive battery wire (which will be going to the PC8, not the battery).
Cheers for any help
CSBJ is offline
post #2 of 3 Old 11-28-2014, 03:14 PM
That will do it. You can take the fuses out of the circuit as they are going to a fused source but you can leave them in if you don't want to replace any wire.
post #3 of 3 Old 12-03-2014, 05:38 PM Thread Starter
Thanks graywolf
CSBJ is offline
