Zumo Install - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 03-31-2008, 07:14 PM Thread Starter
Zumo Install
I just ordered a Zumo 550 and am looking for pointers with wiring it to the bike. Does the Wee have OEM leads that I can use or will I need to wire it into an existing circuit? I'm really hoping there are some leads I can use because I dread anything electrical (much better with the mechanical).
hyak107 is offline
post #2 of 12 Old 03-31-2008, 07:37 PM
Mr.Metal's Avatar
I think your options are to either tap into an existing wire (Posi-Taps?) or buy a fuse box and wire to that. Alternatively, you can try to wire into the factory grip heater connector. I guess you could wire the Zumo directly to the battery, but what's the fun in that?
2008 DL650 a.k.a. Road Warrior, member #16 of the Flat Black Club
2009 Aprilia Tuono 1000R a.k.a. Silver Thunder
Mr.Metal is offline
post #3 of 12 Old 03-31-2008, 07:46 PM
Sudzz's Avatar
I went directly to the battery. It was easy since I already have a battery tender lead on it. I found a mating end and spliced it onto the lead for the Zumo. When I need to plug the tender in, I just unplug the Zumo. No need to get fancy unless you absolutely have to have it wired to a switched power source.
[SIZE="2"][SIZE="1"]DL650K7 - Blue
Madstad Bracket = Awesome!
Emgo Mirrors = Work and Look Great
Cortech Sport Tailbag = Very nice
Cortech 10L Tankbag = Another nice piece
MSR Dominator ATV Hi Bars = Give the bike a whole different feel
Suzuki Gel Seat = Best so far but still not 100% for me
Bestem (Ebay) 2012 42L Top Case = Best bang for the buck!
Modified V-Stream Windshield = Works well
Zumo 550 = Brilliant!!![/SIZE][/SIZE]
Sudzz is offline
post #4 of 12 Old 03-31-2008, 08:04 PM
ElBando's Avatar
You could wire it to the battery and that way have the ability to play with the GPS, program it and such without having the key on. That is how I have mine set up. The down side is you have to turn it off and on when you stop. When I fuel up I shut the key off and monkey with the Zumo for a while so having it on a hot circuit is good for me. If you want it on a keyed circuit a good place to tap is your tail light or the OEM heated grip circuit ( if you can find it).
2007 DL650 ABS ( she thinks it's hers, but it's MINE )
2006 GL1800 ABS ( ours )
2001 VLX600 ( spare )
2000 4X4 Rancher ( his )
2000 4X4 Rancher ( hers )
1991 XL250R ( hers )
1983 XR250L ( his )
1974 CB360 ( retired )
All from the same people who
brought to you "PEARL HARBOR"
Patriot Guard Rider
AMA Member
U.S. Navy Veteran
ElBando is offline
post #5 of 12 Old 03-31-2008, 08:12 PM
Mr.Metal's Avatar
The ideas above have merits. However, my argument is that you want no more than one extra wire connected to your battery, preferably that of the fuse box power lead. That way, the chances of the battery terminals coming lose are greatly diminished. Additionally, a fuse box will allow great flexibility and protection for all of your electrical gadgets. Lastly, you can get fuse boxes that have both switched and direct power, getting the best of both worlds (GPS and battery tender go direct, lights, horn, etc. go switched).
Just my $.02
Mr.Metal is offline
post #6 of 12 Old 03-31-2008, 09:08 PM
roger123's Avatar
I have my Zumo wired directly off the battery. I like it staying on (yes, I know it gives you a nag screen option t0o continue on battery power).
It's very easy to connect this way as it comes with the battery harness.
Roger ('14 Tenere ES, COG 5903)
roger123 is offline
post #7 of 12 Old 04-01-2008, 11:26 PM Thread Starter
Thanks for the replies, I wound up running it straight to the battery which was simple enough. You know, at first I wasn't sure if the Zumo was worth $648, but after seeing everything that came with it I changed my mind. It's a really great set up. Next step is to find a bluetooth headset (does it ever end)!
hyak107 is offline
post #8 of 12 Old 04-01-2008, 11:52 PM
Stromtrooper $upporter
mtnhead's Avatar
I wired into a Blue Seas fuse box since I figured I'd be adding additional accessories to the bike.
As for blue tooth headsets, I have one by Cardo Systems, the Scala Teamset (so I can talk to a passenger). I've had it for 8 months and have nothing but good things to say about it. You can read about it here.
Or if you are a solo rider, you can check out this one or this one if you like listening to radio.
If you ride in groups, they just came out with this one.
There is, of course, many other options (brands) out there.
Trevor
07 DL650
Farkles: Emgo mirrors, T-Bags magnetic tank bag, MadStad w/ Givi windshield, Stebel airhorn w/ Pat Walsh, Blue Seas fuse box, RAM camera mount, Garmin Zumo 550, Givi E460 top w/ LED brake light, Givi E21 sides, Acerbis hand guards, Dynojet PCIII, Superbrace, Pazzo shorty levers, Hot Grips, Elka rear shock, Richland Rick Mirror Extenders, Custom Saddlemen Seat, Murph's Center Stand
mtnhead is offline
post #9 of 12 Old 04-02-2008, 07:28 AM
roger123's Avatar
+1, Love my Zumo, worth every penny.
roger123 is offline
post #10 of 12 Old 04-02-2008, 07:58 AM Thread Starter
Thanks Mtnhead, I was trying not to order more stuff for my new Wee, but you had to go and post a link to the Scala Rider FM. Needless to say I was forced to order one.
hyak107 is offline
