Radar Detector Hardwire Questions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 03-29-2008, 08:45 PM Thread Starter
brian_fairleigh's Avatar
I'm trying to hardwire my Passport 8500 and being an electrical idiot, I need help. I'm trying to use a tap connector (http://www.posi-lock.com/posiplug.html) and I don't know what wire to tap. If I use the rear brake light switch, do I just tap the orange wire? Is there a better wire (such as tailight) that I should use? Also, can I just attach the ground wire to the negative battery terminal? I considered a fuse box relay and ground block, but this is all the electrical stuff I'm doing so that would be overkill. Thanks for the help.
[B][COLOR="Navy"]Ride the bike [I]you[/I] want, where [I]you[/I] want to ride, whenever [I]you[/I] want to.[/COLOR][/B]
[COLOR="Red"][B]Having common sense makes you uncommonly sensible.[/B][/COLOR][SIZE="1"]
[COLOR="DarkGreen"]
[U][B]Current:[/B][/U]
2007 V-Strom 650, Blue: Sargent Seat, Givi Crash Bars, MadStad, Dan Vesel Rad & Oil Cooler Guards, Dan Vesel Luggage Guard w/Tube, Nelson-Rigg CL-850 Bags (sometimes), Fenda Extenda, Pat Walsh Radar Shelf, Marc Parnes LED Radar Alert
2010 VFR1200F DCT
[U][B]Past:[/B] [/U]
2003 VFR800ABS...Sold
2003 Dyna Low Rider...Sold
1984 Gold Wing...R.I.P.
Old Dirt Bikes: Too Many to List!
[/COLOR][/SIZE]
brian_fairleigh is offline
post #2 of 3 Old 03-29-2008, 09:51 PM
The brake light switch wire is orange with a green stripe. The tail light wire is the brown wire in the sheath along the left side of the under seat tray. Either will work as ignition on sources. Do use the negative battery terminal for ground.
post #3 of 3 Old 03-30-2008, 12:02 AM Thread Starter
Thanks Greywolf! You da man.
[COLOR="DarkGreen"]
2010 VFR1200F DCT
[/COLOR][/SIZE]
