No Wire install of GPS and Back up - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 03-22-2008, 07:38 PM Thread Starter
Bitter Born's Avatar
Talking No Wire install of GPS and Back up
Primary GPS
Must mount as high as possible above gages to remove interference from servos
Backup GPS
Bitter Born is offline
post #2 of 5 Old 03-23-2008, 09:05 AM
sock puppet's Avatar
Very slick install! Can one expect any interference if using a magnetic tankbag? Is your system weatherproof? I see no security measures, aren't you concerned about theft? Are you satisfied with the volume level of the voice prompt feature? Have you noticed any glare from the sun on the GPS display?
2006 Wee Strom: GIVI crash bars, luggage brackets with E36N side cases, E45 top case with Amotostuff mounting assembly; Murph's fork brace; DV skid plate, radiator, oil cooler guard; Hepco & Becker center stand; Zuk gel seat, hanguards and tank bra; Oxford heated grips; Garmin 2610 GPS; Fenda Extenda; Blue Sea fuse box;
2003 Ducati Monster 800Si.e with a few mods.
sock puppet is offline
post #3 of 5 Old 03-23-2008, 09:19 AM Thread Starter
It is sensitive to magnetic fields, I originally installed it at the bottom of the screen and as soon as the key is turned on the servos on the gages causes inaccurate readings.
I have yet to come across rain but the unit remained secure for 300 miles even in stiff cross winds.
Very worried about theft with this unit. However it does come with a quick release mounting system and is small enough to fit in your pocket when going in to your finer establisments.
The voice prompt is lacking on this particular model but it does come with features I have yet to find on any other model. It has a built in road surface and shock analysis system. If the road is in disrepair or your shocks are too stiff it displays a series of small bubbles and froth at the top of the display. It also has a 3 dimensional inclinemeter that shows you your exact lean angle, wheelie angle and helps you get the bike perfectly level when checking oil.
So far glare has not been an issue.
post #4 of 5 Old 03-23-2008, 08:47 PM
Ha ha kewl. I had installed one of those stickum Compasses on my R11GS once and the dang thing spun so much that it turned to dust inside the plastic bubble. I still grin when I think of that experiment gone blah.
[FONT="Comic Sans MS"]'43 Andy Chesley
Cajun Country
'00KLR650, '07GXF1250S[/FONT]
Andy Chesley is offline
post #5 of 5 Old 03-24-2008, 06:51 AM
ElBando's Avatar
But that has a built in problem. If you are on the North pole, every direction you take will read South. Then what???
2007 DL650 ABS ( she thinks it's hers, but it's MINE )
2006 GL1800 ABS ( ours )
2001 VLX600 ( spare )
2000 4X4 Rancher ( his )
2000 4X4 Rancher ( hers )
1991 XL250R ( hers )
1983 XR250L ( his )
1974 CB360 ( retired )
All from the same people who
brought to you "PEARL HARBOR"
Patriot Guard Rider
AMA Member
U.S. Navy Veteran
ElBando is offline
