GPS--Garmin 60Cx vs 76Cx - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 03-04-2008, 03:41 PM Thread Starter
shawmutt's Avatar
https://buy.garmin.com/shop/compare....areProduct=350
It's down to these two. The 76Cx floats (for when I take it off my bike and go fishing), accepts higher memory cards, and seems to have the better screen (transflexive). I can get it for about $30 more.
I've found a ton of info here about the 60Cx, but does anyone have any experience with the 76? Would it mount the same as the 60?
edit: and a question--I can enter lat, long coordinates in these as well right? Is it a touch screen? If not, how much of a pain is it to enter these by hand?
~Mike Shaw
AMA# 975261
[COLOR="Blue"]'07 Wee "Slightly Dangerous"[/COLOR]
[SIZE="1"][I]Farkles: Givi Engine Guards, Suzuki knuckle covers, Givi E52 mounted on AMS adjustable plate, Garmin 76CSx on Garmin handlebar mount, Madstad windshield bracket[/I][/SIZE]
shawmutt is offline
post #2 of 7 Old 03-04-2008, 05:26 PM
V-Tom's Avatar
My understanding of the two units is that functionally they are pretty much the same thing. if there are differences they are minor.
Neither has a touch screen. They are not super easy to put in coordinates although they aren't terribly hard, either, just a bit fiddly. They do hook up easily to a computer using USB and in that case it is real easy to enter in waypoints, etc.
..Tom
SMIDSY detailed report.
V-Tom is offline
post #3 of 7 Old 03-04-2008, 06:48 PM
Martin's Avatar
Did you consider the new Garmin Colorado? Pricey sucker, but pretty cool graphics and features... doesn't float though...
https://buy.garmin.com/shop/shop.do?pID=11019
2019 650X
Martin is offline
post #4 of 7 Old 03-04-2008, 07:44 PM
Mr.Metal's Avatar
What features do you particularly want from the 60cx? Have you considered the Zumo 450? After you're done buying the maps for your 60cx, along with a RAM mount and power cable, you're basically at the price of a Zumo 450. I think it's worth a consideration.
2008 DL650 a.k.a. Road Warrior, member #16 of the Flat Black Club
2009 Aprilia Tuono 1000R a.k.a. Silver Thunder
Mr.Metal is offline
post #5 of 7 Old 03-04-2008, 08:35 PM Thread Starter
shawmutt's Avatar
$300 is about my limit. I really don't see anything all that different about the Colorado besides onboard memory, a picture viewer, and the ability to share between units. It does have a couple map preloads though...
I want it to be versatile. I want to be able find a coordinate on my fishing guide, punch it in, get as close as I can with my bike, and then hike the rest of the way.
I'll also be using it this fall to hike around and find some nice hunting spots.
Basically, I need an all-around type GPS.
~Mike Shaw
AMA# 975261
shawmutt is offline
post #6 of 7 Old 03-05-2008, 12:47 AM
Mr.Metal's Avatar
Ok, then it sounds like the 60cx (or maybe 60csx?) is the best choice for you. I don't know if you'd be much happier with the 76cx, unless you plan on dropping it in the water a lot
Don't forget that you still have to pick up maps for the unit, as the base maps suck.
Mr.Metal is offline
post #7 of 7 Old 03-05-2008, 01:48 PM
rhbell's Avatar
60 versus 76
Outside of my post earlier this week about how the 60 CX is a "smokin hot unit"...........I've had a 60 Cx for 3 years - overall it's a good unit. I had some concerns, documented - regarding what I thought were flows in the case design around the junction of the bottom of the display and the case housing sides - I had minor cracks which I solved by sealing with cyroanulate glue.
The operational characteristics of the unit -menus etc are relatively inutitive to figure out but clearly not a "point and shoot interface". Versatile though and does fishing , hiking , geocaching and biking for me quite satisfactorily. . I also use (borrowed) a 76CSX. Outside of altimeter and elecronic compass feature -the units are virtually identical in operation and function. the 76 floats and is a little larger in the hand than the 60 which is advertised more for the hiking type community. Also-- the controls are on top of the screen in the 76, which means you might cover up some details momentarily when operating the controls but this is a moot point with me. On the other hand, the buttons are larger. Since I fish a lot, both wading and boating, , the 76CSX is what I'm getting as a replacement for my now defunct 60 CX. The case also appears a little more "robust" but only time will tell if that is true. In Great White north, the 76 comes with a 128mb card, the 60 only with a 64 Mb card - if that makes a difference.
One man's experience.....safe riding
Bob
Necessity may be the mother of invention, but desperation is it's father........... (Bell)
'06 DL650
rhbell is offline
