Mounting electronic Toys - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 03-02-2008, 04:50 PM Thread Starter
V-Tom's Avatar
Those of you with iPods or the like, where and how are you mounting them? Are they going in your pockets, tank bag, or mounted somewhere?
What about Radios for communication and/or cell phones? I suspect locations for these are a bit more important.
..Tom
SMIDSY detailed report.
V-Tom is online now
post #2 of 11 Old 03-02-2008, 04:54 PM
tmcgee's Avatar
I use the tank bag as control-central for pretty much everything.
2 Meter Ham, FRS/GMRS, Autocom, iPod...
The Zumo is bluetoothed to the phone which is in my pocket. The Zumo also is connected to the XM and has a memory card for MP3 playback.
tmcgee is offline
post #3 of 11 Old 03-03-2008, 10:20 AM
Hey Tom
I have an Air Click which is a wireless remote for the Ipod I have it Velcroed to the bars and the Ipod in my pocket or under the seat if I am using my Starcom.
The Air Click is really good you can change volume, skip, pause, I picked it up at Best buy for 20 or 30 bucks
CYKZflyer is offline
post #4 of 11 Old 03-06-2008, 03:06 PM
klong's Avatar
For my MP3 I use a Tech Mount steering stem mount from Cycle Gadgets: http://cyclegadgets.com/Products/product.asp?Item=HG I used the 1/2" (13mm) stem mount; it's just loose enough that I can move it around a bit, but won't move by itself - there are 2 o-rings keeping it in place, and if it does loosen up I'm sure you can change to larger o-rings.
I put velcro on the plate and back of the player and haven't lost it yet, even on an 18 hr ride to KC last Sept.
I use the same plate to mount stopwatches on during bicycle races.
I use both the straight and angled RAM mounts for radios, GPS, etc. mounted under the mirror arm; the angled one will fit if you just ream out the hole a tiny bit. (http://cyclegadgets.com/Products/pro...sp?item=RAM-BA)
AND,,,, as if I didn't already have more mounting options than stuff to mount, I also modified my (Wolfman Explorer Lite) tankbag; it was real floppy at the top and wouldn't stand up straight (a common issue thru-out my life), so I cut a piece of lexan and installed it against the front wall; I added a powerlet tankbag socket on one side and a ram mount on the other side (w/ a BIG washer on the inside for support).
The bag-mounted stuff is unobtrusive and allows me to take my "stuff" (a guy's gotta have his stuff) w/ me when I use a different bike.
KevinL
VA
..Tom
klong is offline
post #5 of 11 Old 03-08-2008, 01:29 PM Thread Starter
V-Tom's Avatar
Hi Kevin,
By any chance could you post a picture of how you have everything laid out on your bike?
..Tom
V-Tom is online now
post #6 of 11 Old 03-08-2008, 06:38 PM
Clever Title
My DarienLight pants came with velcro strips on the left leg. I put some velcro on the back of my Sansa .mp3 player and stick it to my pants. I run the cord for my headphones through my jacket. No cord dangling in the breeze, but it's tough to look at the screen on the player. Usually not an issue for me, tho.
Guess I should have been wearing pants...
'86 Suzuki GS450L (redneck-farkled)
'79 Yamaha XS1100 (project bike)
'06 Suzuki DL650 (SW-MOTECH: centerstand, bellypan, crashguards) (3M reflective striping) (Powermadd handguards) (Nelson-Rigg saddlebags and tankbag)
iron_llama is offline
post #7 of 11 Old 03-13-2008, 10:34 AM
Handle Bar Mounts
I took the handle bar mounts from a couple of old battery operated bicycle headlights and used them to mount my XM radio and my cell phone to the bars. They are in two pieces that have a spring clip to snap them together allowing for easy attachment/removal with the Bike. I used double sided tape and pop rivets to attach the brackets to the cases.
DL650K7: Audiovox CCS-100, (2) 12 Volt accessory plugs /w dashboard, Blue Sea (6) fuse box, Rox Risers 2"x7/8x1 1/8, Pro Taper Cr-Hi Handlebars, KTM Handguards, Deltran Battery tender, LED Voltage Monitor, XM Sat. Radio, SW Motech Side Case Racks, Hepco Becker 40L side cases and 45S Top Case, Hepco Becker Engine Guards, and AMotoStuff Skid Plate.
d_dub is offline
post #8 of 11 Old 03-13-2008, 02:57 PM
i myself plan on using a shelf that i have come with. it mounts between the fairing bolts that are at the upper "points" and "wedges" between the fairing and the windscreen bracket.
i don't have any pictures since i'm in the middle of a move and all the parts are in storage. there are similar units available but i liked my mounting better.
since my project is on hold during the move i'm also playing with a windscreen lowering/raising modification... like some of the more expensive bikes.
Jeff
Blue 2005 DL-650 (2005 - present)
83 Honda Shadow 750 (sold for parts)
70 Bridgestone 100 (oil injector) ("Blown-up, Sir")
Jeffjan2001 is offline
post #9 of 11 Old 04-21-2008, 08:00 PM Thread Starter
V-Tom's Avatar
Was that you on Sunday on the ride?
I meant to look.. how do you have your wiring set up? I have an Autocom setup that I have been fiddling with. So far I have only had it in a tankbag whiel I tried things out.
Now that I know everything works well I am wondering what the neatest way would be to do all the wiring. I think I would like to leave the Autocom under the seat and have the wires run to the FRS Radio, to the music player, etc. I don't want a mess of spagetti, though.
I don't yet have an iPod but the rest of my family does. I do have an MP3 playe but it isn't Apple. Your remote control might make me go out and get an iPod in the future as that was pretty slick.
Any suggestions?
..Tom
Originally Posted by CYKZflyer View Post
Hey Tom
V-Tom is online now
post #10 of 11 Old 05-02-2008, 10:22 AM
Hey Tom
ya that was me on the ride.I really like the ipod and airclick combo.I haven't finalized my layout with the starcom but I am very close.I am having a problem with the ipod under the seat it seems to lock up, not sure if it is a ipod problem or location/virbration issue.I want to have everything under the seat that I can to reduce wires and improve security.I don't mind riding with the tank bag but would like the option of not having it but still have com and tunes.
I have ordered some more cables for the Starcom and plan to pull of the tank and do the job right in the next couple of weeks.
