scorpio alarms - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 02-18-2008, 09:27 PM Thread Starter
dzedella's Avatar
scorpio alarms
anyone ever install these systems on a v-strom....seem pretty simple to install.....also considering a xena disc alarm...any thoughts....live in the middle of the city, need to do something...
dzedella is offline
post #2 of 17 Old 02-19-2008, 12:44 PM
BubbaGee's Avatar
Send a message via MSN to BubbaGee
I've got one(SR-i500) on mine but had it installed by the dealer when I got the bike, so can't give any help with how the install is. I did have them use the connector kit for it so no splicing was needed. It has worked well for me so far. Just keep in mind that if you store the bike and the alarm is on it will drain the battery. The longest I've let it sit without starting it and not having a charger on it has been 3 weeks and it was fine.
BubbaGee
2006 DL1000 in red.
"What doesn't kill you only makes you stronger."
BubbaGee is offline
post #3 of 17 Old 02-19-2008, 04:45 PM
I installed one on my 650, no problem. I used the connector kit sold by Scorpio easy plug in installation. I ordered mine with the perimeter alarm and use it when I'm leaving gear on the bike. Have had the alarm on the bike since new (2 years) and have had no problems.
Rogues are preferable to imbeciles because they sometimes take a rest.
tac3 is offline
post #4 of 17 Old 02-19-2008, 08:23 PM Thread Starter
dzedella's Avatar
you just need to remove the seat to install...right?
dzedella is offline
post #5 of 17 Old 02-20-2008, 11:36 AM
I mounted my "brain" behind the battery, on the front edge of the tray - moved one of the relays. The perimeter alarm sensor mounted at the right side near the back and the antenna I routed along the left side sub frame rails. A little hard to get to the rear light/brake light wiring to make the connections to the lights, but other than that it is a simple installation.
tac3 is offline
post #6 of 17 Old 02-20-2008, 01:42 PM Thread Starter
dzedella's Avatar
thanks for the information...i will order soon......
dzedella is offline
post #7 of 17 Old 02-20-2008, 07:46 PM
Masked1's Avatar
I could show you a pic or two if you like.
08 Vee
Masked1 is offline
post #8 of 17 Old 02-20-2008, 08:57 PM Thread Starter
dzedella's Avatar
that would help me get a better idea...thanks.
dzedella is offline
post #9 of 17 Old 02-21-2008, 08:59 AM
Masked1's Avatar
Ill try to fit it in after work today
08 Vee
Masked1 is offline
post #10 of 17 Old 02-22-2008, 07:55 PM
Masked1's Avatar
Here's a couple pics...I didnt install it dealer did it for me before I picked the bike up..hope these help.
08 Vee
Masked1 is offline
