Galaxy S3 + Scala Rider Q2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 06-22-2014, 03:14 PM Thread Starter
njbill's Avatar
I cannot get my S3 to play navigation prompts through my Scala headset. It works fine with phone calls but the navigation prompts still play through the phone speaker. I do not plan to take/make calls while riding. I only want to hear the navigation prompts. Has anyone solved this problem?
njbill is offline
post #2 of 3 Old 06-24-2014, 11:05 AM
JackinCT's Avatar
There are two different profiles to connect a phone to a blue tooth headset - audio and phone.
When I first tried my Sony phone with my headset I got what you are getting because it use the phone profile by default. If it used the audio profile to connect it I got everything through the headset.
I do not have my Scala any more but it wasn't the set up on there, it was the set up on my phone that made the difference. Try having a music player open when you're first pairing them and maybe it will switch to the audio profile for you. That was the trick that worked for me.
JackinCT is offline
post #3 of 3 Old 06-24-2014, 03:30 PM Thread Starter
njbill's Avatar
Thanks for that suggestion. I tried it but cannot get any profile but phone audio.
njbill is offline
