sena smh5 problems - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Downs
post #1 of 8 Old 06-11-2014, 10:16 PM Thread Starter
Matthew6279's Avatar
sena smh5 problems
Ok so I just bought the sena smh5 headset. One for me one for my wife on pillion. I have a brand new Samsung Galaxy s5 she had an apple 4. We both have problems with music cutting in and out. Doesn't matter what app. We have strong signal to so I don't think it's that. I did the firmware update too. Anyone else run in to this? ?
Current:
2014 V Strom 650 - V46 topcase, E41 side cases, Suzuki lower fairing, Givi Airflow windscreen, Ram mount handlebar mount and pda case for my phone, 12v power at handlebars, Dan Vesel Highway bars with Rivco pegs, Dan Vesel passenger peg relocate with Kuryakyn bolt on floor boards, Adventure Tech fork brace, Extuff helmet hooks, Ram mount cup holder, 12v/usb/voltage meter all in one mounted to brake reservoir, Happy Trail center stand, SV racing foam grip covers, Kolpin handlebar mitts, Moose Contour hand guards.
1982 Honda XL 250
1981 Honda XL 185
1990 KX 250
Polaris Sportsman 570 touring
Previous:
2006 Yamaha R6
2003 Yamaha R1
2002 Yamaha R1
2001 Yamaha FZ1
1974 Honda CB360
1982 Honda CT200
1988 Honda CR 80
Matthew6279 is offline
post #2 of 8 Old 06-11-2014, 11:19 PM
Downs's Avatar
Make sure your VOX option is turned "off".
Downs is offline
post #3 of 8 Old 06-11-2014, 11:39 PM Thread Starter
That will fix the music cutting out?
Current:
1982 Honda XL 250
1981 Honda XL 185
1990 KX 250
Previous:
2006 Yamaha R6
2003 Yamaha R1
2002 Yamaha R1
2001 Yamaha FZ1
1974 Honda CB360
1982 Honda CT200
1988 Honda CR 80
post #4 of 8 Old 06-12-2014, 01:35 AM
Downs's Avatar
I don't know if that's the problem with yours but it could be. You have to hook your SENA up to your computer and run the software to see if it's on.
If you have intercom VOX enabled it will try to open the intercom channel if you are too loud or singing to your self or something like that which will interrupt your music.
Beyond that try clearing all your pairings and starting over again.
realshelby likes this.
Downs is offline
post #5 of 8 Old 06-15-2014, 04:31 PM Thread Starter
I tried turning the VOx off with no luck. It still cuts in and out a lot. Brand new Samsung Galaxy S5 and the communicator is brand new as well. My wifes one does it with her Iphone and I paired a Droid Razr MAxx and it does it as well. Hmm... I have tried several different apps too - Pandora, Spotify, TuneIn Radio. Im going to email Sena.
Current:
1982 Honda XL 250
1981 Honda XL 185
1990 KX 250
Previous:
2006 Yamaha R6
2003 Yamaha R1
2002 Yamaha R1
2001 Yamaha FZ1
1974 Honda CB360
1982 Honda CT200
1988 Honda CR 80
post #6 of 8 Old 06-15-2014, 05:34 PM
Downs's Avatar
There's another setting in there that deals with the bluetooth data rate or quality. Try turning that off. It gives you little hints next to all the settings you can change to tell you what they do.
I remember one talking about if you experience data drops or something to turn this setting off to clear up the issue. I don't have my software here at work but when I get home I'll take a look and see if I can find it.
Downs is offline
post #7 of 8 Old 05-20-2016, 07:30 PM
@Matthew6279 did you have a solution? I have a SMH5 with the same problem.
The VOX Settings is disabled.
post #8 of 8 Old 05-31-2016, 05:38 AM
FWIW, I had to do a reset with my SMH10R while going through the process of pairing it to a Scala Rider 9x. The VOX was turned on and the music cut in and out as the intercom kept trying to cut in.
Changed settings to VOX off and the issue has resolved itself.
Good luck.
Bob
07 Wee
10 NT 700
BobAgain is offline
