secret menu in zumo-get voltmeter and thermometer out? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 01-28-2008, 06:40 PM Thread Starter
Hi guys
so I just stumbled on a secret zumo menu- if you put your finger on the clock in the upper right hand side for about 10 seconds, a secret menu comes up. there's a bunch of info, but most startling is a thermometer and an incoming voltage meter. can anyone with more computer skills than me figure out how to get that info on the normal screen??? that would rock. i can't believe garmin didn't put that info out there to begin with.
crazyrussian is offline
post #2 of 19 Old 01-28-2008, 06:46 PM Thread Starter
update: the thermometer seems to display the internal temp, which is much higher than ambient temp.... but the voltmeter is still valid!
post #3 of 19 Old 01-25-2010, 08:36 PM
Holy Crap! CrazyRussian, you must be destined to save me money. First the bracket and now the free voltmeter. I think i'm into you for at least $160. :P
At least a beer if we ever run into each other!
darkjedip is offline
post #4 of 19 Old 01-25-2010, 08:38 PM
It's probably the skinny wires leading to the Zumo, but its voltage reading is always lower than my voltmeter's.
post #5 of 19 Old 01-27-2010, 01:33 PM
568v8's Avatar
zumo voltmeter
Wish I'd know about the voltmeter.
Recently, driving my Subaru with the Zumo in the car cradddle, I was suspicious of the idiot battery warning light. Too bad ... I had a breakdown requireing a new alternator. The Zumo would have aided me in the diagnosis and saved a hassle.
Road Toads Charter Member - old guy goes stromabout on a 2007 Vee and finally has touched all of the 48 contiguous United states and the 10 Canadian provinces.
568v8 is offline
post #6 of 19 Old 07-17-2010, 04:35 PM
Unhappy Problems with Zumo 550
Tried this trick w/my 550. The info looked cool, but a couple of minutes later, my unit locked up. No buttons would work and screen had stopped loading a new map. Wasn't sure what happened. Tried to call Garmin and was told it would be a 30 minute wait. Went home and waited for battery to die. Plugged it back into the charger and all was OK.
Not thinking there was a connection, I told my wife of the discovery so we wouldn't have to buy voltmeters. While driving to a business conference, she tried it on her 550 and was excited about the functionality. She called back later and said that she had driven past her exit because her Zumo had not updated her location in a while and was locked up. No buttons worked. I told her of my similar experience and she let her unit's battery die. When plugged back in, it was working again.
Coincidence? I don't think so.
owlarry is offline
post #7 of 19 Old 07-17-2010, 05:25 PM
The function change locks out normal operation. With software version 4.80, there should be an Exit icon at the bottom of the screen. Holding down the lower right button for a second should turn the unit off. Holding the lower right and upper left buttons simultaneously will reset the unit. In extreme problem cases, take out the battery for a few seconds.
post #8 of 19 Old 07-17-2010, 05:33 PM
JoWhee's Avatar
My streetpilot 2610 has a similar menu, but it's easy to reboot it, there's a switch on the side. If you want to trade.. Ya, I didn't think so.
2003 DL 1000
JoWhee is offline
post #9 of 19 Old 07-19-2010, 08:17 AM
Thanx.
Pat- thanx for the info, but the lower right button didn't respond. I'll try the lower right and upper left next time. Wasn't carrying a small allen wrench for battery, but am now.
Like your map. How do you do that? Asked admin how to do it, but didn't get response.
owlarry is offline
post #10 of 19 Old 07-19-2010, 10:03 AM
What version of software do you have? It may be past due for a free upgrade. https://www.stromtrooper.com/forums/s...ad.php?t=48472 has map and picture info.
