GPS Mount - shelf or RAM? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 34 Old 01-07-2008, 09:29 PM Thread Starter
phoenixtoohot's Avatar
Which way should I go? The Pat Walsh shelf or RAM mount on the handlebars? From what I can see, the shelf would give a better "heads up" display and would keep the GPS pointed in the direction of the bike, not the handlebars. The RAM might get the unit closer to the eyes. Comments appreciated.
Indecision is the key to flexibility.
06 DL1000
07 Ducati ST3
phoenixtoohot is offline
post #2 of 34 Old 01-07-2008, 09:33 PM
Destro's Avatar
I have the Walsh shelf and although I have not parked a GPS on it I would rather a RAM mount on the bars. I rigged a camera mount to the shelf and under hard acceleration I get enough vibration through the shelf to make the picture unusable. The shelf is just not beefy enough for a small camera. I run ATV bars with a crossbar and I think a RAM mount on the cross would be ideal.
DESTRO
Psalm 23
DL1000 Pilot
http://my2wheels.com
For Dual Sport riders of the southwest
Destro is offline
post #3 of 34 Old 01-08-2008, 04:46 PM
Bisbonian's Avatar
I have just installed the Pat Walsh shelf and mounted my GPS on it. Haven't got to ride it yet but I can't imagine that I'll get enough vibration to cause any troubles. Of course I'm using a Garmin Etrex Legend and don't intend to interact with my GPS that much. If you're going for the all-out navigation system where you're going to be touching the screen and such I would mount it to the bars with a RAM mount only because the shelf is a little far away and you may have less control reaching up there.
Go hang a salami I'm a lasagna hog
Bisbonian is offline
post #4 of 34 Old 01-08-2008, 06:08 PM
SaPPeR's Avatar
Not a cheap option but I like it. Ram mounting point right on top of the dash so my Zumo is right above my dash. Not sure if it works with the madshat (sp?) windshiled mount.
http://www.adventurersworkshop.com/M...1000_GPS_MOUNT
SaPPeR
02 RSV-R Aprilia
07 Warrior 1700
PhoTos
SaPPeR is offline
post #5 of 34 Old 01-08-2008, 06:45 PM
JPryce's Avatar
I mounted my Zumo on a Pat Walsh Shelf using a round RAM mount base and the arm the GPS came with. It allows for just the right amount of adjustment and places it within easy reach and directly in my field of view. Unfortunately, the shelf vibrates like crazy on anything less than a smooth road. The Zumo seems a bit heavier than most, so other GPS units may not move around as much as mine.
2012 Super Tenere
2006 CRF50 with big-boy mods. :biggrin:
1973 RD350
JPryce is offline
post #6 of 34 Old 01-08-2008, 09:07 PM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
Got the ram mount on my pat walsh shelf.
I dont notice any more vibration than I was getting through the handle bar mount.
The shelf puts it in my line of sight better, so I do not have to look away from the road.
Much better on the shelf in my opinion
Mike
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
post #7 of 34 Old 01-08-2008, 11:13 PM
I've had it with the bouncing so I just made a rigid mount. It uses a 1/2" x 1" aluminum bar drilled and tapped at the ends for the bike mount and a plate for the Zumo mount instead of the Ram connection pictured below for measurements. New picture's will follow.
post #8 of 34 Old 01-09-2008, 06:50 AM
USAIR's Avatar
I like the ram but I use my 60CSx on 2 bikes and a few different cars.
I use the u-bolt on the bikes and suction for windshield for the cars.
I think it depends on what unit you have.
The shelf sure looks nice with the Zumo.
Fred
USAIR is offline
post #9 of 34 Old 01-09-2008, 03:09 PM Thread Starter
Well, I made a shelf yesterday and will give it a try. If it does not work for the GPS, I'll keep the shelf for other things. Used a piece of 18 gauge metal from True Value for $7 and attached at 4 points.
06 DL1000
07 Ducati ST3
post #10 of 34 Old 01-09-2008, 04:20 PM
Here's the aluminum rigid mount. The bottom is a 1-1/2" x 1/8" thick angle. The arm is 1"x1/2" and the zumo mounting plate is 2"x 1/8" thick. Connections are by two screws tapped into the arm at each end. The top screws are 1/4-20 brass oval head with the heads filed down and the bottom is a 1/4-20 and a 4mm. I just used what I had lying around. Some JB weld will keep anything from coming loose. I tried it out by going to lunch in Wisconsin today. It's way easier to read than the Ram mount. I don't have a warm place to spray paint so I'll clean it up and paint it in the spring. I may cross drill a couple of 1/2" holes in the arm for looks. It wouldn't lower the weight much.
