NavMan N40i NavPix 3.5" Touchscreen GPS - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 1 Old 12-12-2007, 10:29 AM Thread Starter
oh2RideMore's Avatar
Woot has NavMan N40i NavPix 3.5" Touchscreen GPS for $159.99 today. Not sure if this is a good gps, but includes maps of USA, Canada, and Puerto Rico.
http://www.woot.com
Features:
* Large 3.5” touchscreen
* NavPix compatibility so you can download and then use NavPix to navigate
* Integrated 1.3 Mega Pixel NavPix camera
* Nearest Fuel and Park buttons to alert you to the nearest gas station or car park
* Reliable, accurate GPS navigation
* Advanced Motorway Navigation
* Journey View function
* Enhanced battery life, up to 5 hours depending on use
* Greatly improved finger friendly interface
* Pre-installed safety camera data
* POI import capability, so you can add your own points of interest, such as safety cameras
* Drive-Away™ so it’s ready to use out of the box
* Automatic re-routing with Back-on-Track™
* Memory: 2GB flash built in on US version, 2GB SD card included with Canadian version. Hardware is otherwise identical. Both versions come with US, Canada, Puerto Rico and Guam maps on CD. You'll receive one of these two versions.
Hardware
* Weight: 2.4 Lbs.
* Size: 9 1/2”81mm (H) x 6 1/4” (W) x 5 1/2”(D)
* Camera: Yes
* SD card slot
* Processor: Samsung 244-400MHz
* Battery: Rechargeable integrated Li ION – up to 5hrs life
* High-quality loudspeaker: Yes
* GPS Receiver: SiRFstarIII™ Generation 2
* GPS update rate: Typically every second once fix established
* GPS accuracy: Fix to 5 metres 95% of the time
* Screen: Anti-glare high resolution 3.5” (89mm) color touch-screen
* In-Car Suction Mount: Yes
* Power: 12V in-car power connector
* PC connection: USB 1.1
Software features
* NavPix™ navigation to pictures
* Journey View
* Drive-Away™
* Back-on-Track™
* POI (points of interest – transport-related POIs)
* Nearest POI/POI import
* Voice guided instructions
* Favorite destinations stored
* Multiple routing options, eg, shortest/fastest, nearest POI
Navigation views
* Turn-by-Turn™
* Next maneuver
* 3D Moving map (adjust 3D zoom mode downwards to achieve 2D moving map mode)
* 2D Mini map
Mapping
* Tele Atlas 2006
* SmartST™ 2006 SE navigation software
* US maps
What’s in the Box
* Navman N40i GPS
* Vehicle mounting bracket
* Vehicle power adapter
* AC power adapter
* USB cable
* Carrying case
* Software CDs
* 3 CDs with maps of all 50 states, Canada, Puerto Rico and Guam
* Users manual, installation guide and FAQ
oh2RideMore is offline
