Cant get Garmin 2730 to recognize tracks made in Mapsource - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 03-16-2014, 08:48 PM Thread Starter
KTM Mike's Avatar
Ok - go easy on me - GPS Newb Alert!!
I have been searching here, on ADV and elsewhere and cant find the answer.
I have tried this in both Basecamp and Mapsource.
I made a "track" in Basecamp and Mapsource, went through the routine to send it to the 2730. All goes fine. The PC can recognize the file being on the 2730. How do I get the track I made to display on the 2730 such I can follow it? I found a suggestion it must be named Active Log 001 etc. tried that no luck!
BUT - if I instead make a route on the PC (only tried this in mapsource - assume it would be same in basecamp), send it to the unit - yep it appears in my saved routes and seems to work (I have not tried to "drive it" yet - but it appears as a route and all seems good.
Any suggestions?
No longer a Vstrom Owner - fantastic bike! Now sporting a KTM 990 Adventure
KTM Mike is offline
post #2 of 6 Old 03-17-2014, 11:07 PM
Stalky Tracker's Avatar
I have a 2730 and haven't tried tracks so I guess I am no help. :mrgreen: I do use routes. I have used MapSource and now Basecamp and both send the routes to the GPS just fine for me. And I have used them to "drive by" on several multi-week trips.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #3 of 6 Old 03-17-2014, 11:13 PM
V-Tom's Avatar
I don't know specifically about that model of GPS but I have only ever tried sending tracks and routes through Mapsource and Basecamp. Why don't you just use one of those?
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is offline
post #4 of 6 Old 03-17-2014, 11:21 PM Thread Starter
KTM Mike's Avatar
See my original post - I am using Basecamp and/or Mapsource. Creating the track or route there then using them to get them to the 2730. When the GPS is connected to the PC I can "see" the file for the track I created on the PC is now on the GPS - but the GPS does not seem to be able to do anything with the track.
I can send the Routes I have created as well - those work fine. The risk with a route is it "recalculating" mid ride - if for example I screwed up and forgot to shut off the recalc. and I go off route. I messed with all this today in fact - GPS set for no recalc. Started out driving the route - deliberately veered off course - good news - no recalc! Later, I drove back onto the route - but again continued off course - it did a recalc then for some weird reason.
BUT the good news is - the route I loaded remained intact on the unit - so it will end up working out. I would prefer to find a way to use tracks though - eliminates those recalc risks. I am starting to think that will not be possible though.
KTM Mike is offline
post #5 of 6 Old 03-18-2014, 11:05 AM
V-Tom's Avatar
Sorry I misunderstood what you were doing with the tracks.
Last time I used tracks while on roads in a car or bike was with my Garmin eMap.
Once I understood how the units navigate I just added enough waypoints to ensure it follows my intended route. I have ridden literally a few hundred thousand KMS with no issues.
..Tom
My Opinion:
My Stroms:
V-Tom is offline
post #6 of 6 Old 03-27-2014, 10:55 PM Thread Starter
KTM Mike's Avatar
Well I got it to work! Thanks to an inmate over on ADV - I realized the issue was that I was naming the track Active Log...instead of ACTIVE LOG - yep - had to be in all caps for it to be read.
I think the biggest issue is it is very hard to see the line for the track on the GPS - a rather thin dotted line in black - hard to pick out when it is on a road on the map - OK if it were in an area without a road under it. I have not driven with it yet - but will tomorrow to see how hard it is to pick out when driving. (yes...driving....still to much snow here to ride)
Thanks for the help!
KTM Mike is offline
