garmin 660 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 01-02-2014, 05:03 PM Thread Starter
garmin 660
Just got my new farkle but I need to wire it up. Got the mount figured just not sure how to run all the leads. Do I pull everything back to the battery area and just loop the unused leads under the seat? Not sure if I have enough length to do everything. Just thought I would ask before I start. Pictures of wiring? I am using richland ricks gps mount.
Maddog251f is offline
post #2 of 13 Old 01-02-2014, 05:40 PM
madstrom's Avatar
Not sure which year your bike is. I suggest you wire it to a switcged source. I suggest you pull the right side panel off to get better access and better see what you are doing. Then after bolting the gps mount in place and the cradle, run the wiring down beside the windshield mount and into the fairing. Get a bunch of tie wraps and neatly tie wrap the wiring to the fairing bracing and then over the bike's frame near the steering head making sure that you have no interferance with the forks as they rotate. Look for the switched lead behind the radiator. Years 2004-2011 had it on the right side and was for the heated grips option. Years 2012-2014 have two switched leads. There are several threads on this forum and V-Strom Riders International with pictures showing where the leads are. They are all 2 wire leads with Suzuki couplings on them. You may need to undo some electrical tape on the bike's wiring harness to get access and some slack to work with. I suggest you solder the connections and shrink wrap them to seal out dust and moisture. Once you make the the final connections coil any extra wiring from the gps leads and tie wrap them in place. You can get mating leads for them from Eastern Beaver which is an excellent source for any of your wiring requirements.
Link: VStrom
Good Luck
madstrom is offline
post #3 of 13 Old 01-02-2014, 05:46 PM
Stalky Tracker's Avatar
I ran mine (old Garmin 2730) back to the battery area. I installed an Eastern Beaver PC-8 fuse block in the tray under the seat and wired it in there on a switched circuit. If I remember correctly, I had just enough wire to accomplish it. I put the wires in a small diameter wire loom for protection for most of runs length.
Wire looms:
PC-8:
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #4 of 13 Old 01-02-2014, 06:02 PM Thread Starter
Thanks for the quick respose
I am trying to get the wires as supplied by garmin back to the battery area. I intend to wire the gps directly to the battery and then coil the other leads somewhere. Bike is a 2013 dl650. The fuse holder and the other bundled wires don't want to snake back there. Really don't want to cut anything. I do have a cable tv lead snaked to the front.
post #5 of 13 Old 01-03-2014, 02:20 AM
Rolex's Avatar
I had already fitted a 12v cigarette socket to my bike, it is wired to the battery for constant 12v power so I wired my Garmin's power supply to the back of the socket, quick and easy.
So if you don't have a 12v socket you should think about fitting one at the same time as you do the Garmin or if you have a socket it may save you some work.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #6 of 13 Old 01-03-2014, 09:42 AM Thread Starter
good idea so what did you do with the wire bundle? mine on the zumo 660 is about 5 ft long and 4 leads after the junction.
post #7 of 13 Old 01-03-2014, 10:02 AM
V-Tom's Avatar
I wouldn't bother with a switched lead for a GPS unless you are in the habit of leaving it sitting on your bike switched on when you are not around. Direct power is good either to the battery or to an always-on connection of a fuse box.
I mounted my 660 on the left Handlebar of my 2012 DL650. The cable length is pretty good if you run it down in front of the steering area and back` around the left side of the tank. There won't be a lot of excess but what there is can be left in the area behind the left side cover.
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is online now
post #8 of 13 Old 01-03-2014, 10:53 AM Thread Starter
Tom I have my side cover off the one that hides the tank. Did you run your leads behind that side cover? That is what I am going to try next it seems to me that the triangle connecter deal would hold the side cover out and not let it lay flat? Sounds like you did what I want to do. Thanks for the reply any other info is appreciated am going to try this in a few hours.
Thanks again
post #9 of 13 Old 01-03-2014, 12:33 PM
V-Tom's Avatar
I can't say I recall exactly how i doid it as it was about 22 months and 51,000 miles ago. I don't think I removed the tank when I did it but was able to feed it under the left side of the tank. It is very cold here right now and my bike in the back yard buried in snow and ice so I am not anxious to go over and look.
..Tom
My Opinion:
My Stroms:
V-Tom is online now
post #10 of 13 Old 01-03-2014, 12:48 PM
NSdave's Avatar
I mounted mine to the wind screen bracket using a ram ball, that way it is up high enough to keep my eyes on the road,
I used a garmin "motorcycle" lead and fished it under the left side of the tank, the tied it into a relay switched by the rear tail light
Sent from Motorcycle.com App
14' DL1000
NSdave is offline
