Anyone using Gerbing T5 with Warm & Safe Generation 3 gear? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 11-20-2013, 01:03 PM Thread Starter
bobosmite's Avatar
I sent a message to W&S to find out if they are compatible, if they are compatible, I'm curious how well they work together.
2014 Suzuki DL1000
SEARCH is your FRIEND
bobosmite is offline
post #2 of 7 Old 11-20-2013, 01:22 PM
V-Tom's Avatar
I *think* my new Gerbing Gloves are T5 (they are the latest) and I have a Warm and Safe Gen 3 Waterproof Jacket at the Post office waiting to be delivered. WIth luck I'll have it tomorrow.
It was -8c/17f when I left home this AM so the timing is good!
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is online now
post #3 of 7 Old 11-20-2013, 03:01 PM
Each will tell you the other's connections may be troublesome. I've had zero problems running W&S gloves and jacket liners with Gerbing pants liners and boot soles though.
post #4 of 7 Old 11-20-2013, 04:58 PM Thread Starter
bobosmite's Avatar
Awesome. I just went ahead ordered the G3 and T5 to compare.
post #5 of 7 Old 11-20-2013, 06:23 PM
V-Tom's Avatar
My Jacket came this aft. It isn't gong to be as cold tonight when I head home at 8pm but should be at freezing. I went up and checked that all the connections would work and it looks like it should be fine.
My setup wil be:
Gerbing dual controler and Gerbing Gloves and now the Warm n Safe Waterprof Jacket. Only negative is that it looks like Warm n Safe has really set things up for the remote Heat Troller (which I don't have.) the cables are short but there is one adapter to effectively lengthen the power to the jacket There isn't for the glove connection. I think I will still be able to make it reach all right though (and if not I think the short included "Y" adapater could effectively lengthen the power to the Glove Side of things.
..Tom
My Opinion:
My Stroms:
V-Tom is online now
post #6 of 7 Old 11-20-2013, 10:47 PM
V-Tom's Avatar
As expected it worked together just fine!
The Warm N Safe jacket is extremely warm! It was around freezing point on the way home. I had it under my work suit jacket and a thin shell over them then the Roadcrafter. I generally had the heat for the jacket at about the lowest setting. Every so often I would check on it and crank it up and literally in a few seconds it was hot.
Great gear!
..Tom
My Opinion:
My Stroms:
V-Tom is online now
post #7 of 7 Old 11-22-2013, 11:08 AM Thread Starter
bobosmite's Avatar
Both pairs of gloves were too big in XL, so I have to send them back. Gerbing is a little more stylish than First Gear, but they both are pretty much the same.
2014 Suzuki DL1000
