Adhesive for bluetooth controller - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 11-20-2013, 10:29 AM Thread Starter
sbeadg's Avatar
On the advice of a fellow inmate I opted for a generic bluetooth headset. It works fine except if won't clamp on my helmet because its a Nolan which requires using their headset. :headband: That area of the helmet has the flip down shade control...I found this out after watching a Revzilla video. I tried the adhesive backed mounting plate that came with the unit but the adhesive didn't hold despite my cleaning the area on the helmet carefully.
So, does anyone have a recommendation for an adhesive that will hold the mounting plate on? Should I remove the adhesive that is now on the plate and the helmet? With what?
Or do I need to admit that I was being a cheap bastard and get Nolan's bluetooth system? That will be only after attempting a better adhesive. I definitely AM a cheap bastard. :mrgreen:
'15 Tiger800 XRx
'99 Triumph Thunderbird Sport
'89 Honda NX250
"Why don't I have tattoos? For the same reason you don't put a bumper sticker on a Ferrari."
sbeadg is offline
post #2 of 4 Old 11-20-2013, 11:10 AM
Impster's Avatar
I installed a Sena SMH10R headset on my Nolan N-104, using the sticky/velcro they supplied. 8000 miles with it on and no problems.
Original Post:
https://www.stromtrooper.com/maintena...h-install.html
If yours would allow for a sticky/velcro install, Sena sells a separate 'install kit' with the 3M backed velcro:
Sena SMH10R Supplies Kit - RevZilla
Hope this helps.
Chuck
Impster is offline
post #3 of 4 Old 11-20-2013, 11:48 AM
fire fox's Avatar
My Sena is held on by 3m dual sided tape from the auto parts store. It's solid.
fire fox is offline
post #4 of 4 Old 11-20-2013, 12:06 PM
trapperdog's Avatar
My old helmet still has the original blue ant inner com supplied dual stick tape mount on it after 100K miles. Never took it of after installing the clamp mount Cardio. Dual stick tape holds very well when applied correctly
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is offline
