Battery screws too short - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 09-19-2013, 08:13 PM Thread Starter
So I'm trying to connect 2 leads to the battery terminals... The added depth of the 2 connectors makes the screw that connects the hot and ground wires to the battery terminals too short to catch the threads of the nut beneath... I can't possibly be the only one with this issue, can I? Do I just need longer screws?
2013 V-Strom 650 Adventure (commuting machine)
2012 Kymco Like 200i (for fun):biggrinjester:
JPilot is offline
post #2 of 10 Old 09-19-2013, 08:19 PM
We all need longer screws :mrgreen:
Local hardware store should have them.
14 DL650 Adventure
07 DL1000 ( Sold )
05 KLR 650 ( Sold )
01 Vulcan 1500 ( Sold )
55 CJ5
slaghammer is offline
post #3 of 10 Old 09-19-2013, 08:26 PM
With the battery out of the bike thread the screws into the nuts then pull up on the screw and wedge something under the nut to hold the nut up when you remove the screws the nut won't drop down. Should give you enough room to get the screws started with the extra terminals. Use something that doesn't conduct electricity like a piece of plastic or rubber.
coral_snake is offline
post #4 of 10 Old 09-19-2013, 08:45 PM
two_wheeled's Avatar
I cut a small piece of cardboard and shimmed under the nut to hold it up closer to the bolt. Works great, try that.
-Steve in Phx.
Current: 2011 DL650A, Honda XR650L
Lost Loves: 2003 Honda ST1300A, Kawasaki Concours ZG1000, Honda Shadow VT500C, Honda Nighthawk CB700SC, Kawasaki KLR600, Yamaha TT500, Honda XR75
two_wheeled is offline
post #5 of 10 Old 09-19-2013, 09:03 PM
tmcgee's Avatar
I've put longer screws in every motorcycle battery I've owned.
tmcgee is offline
post #6 of 10 Old 09-19-2013, 09:07 PM
jamessveta's Avatar
Send a message via Yahoo to jamessveta
I had the same problem when I started connecting a lot of electrical accessories and I went with one of these and it works good for me....
DualBus Plus 150A BusBar - 1/4"-20 Stud 5 Gang - Blue Sea Systems
jamessveta is offline
post #7 of 10 Old 09-19-2013, 09:15 PM
fortp's Avatar
Just be carefull not install too long bolt, that could break the plastic when tighten them.
fortp is offline
post #8 of 10 Old 09-20-2013, 10:35 AM
davenjai's Avatar
I just always use a small flat blade screwdriver to raise the nut up.
davenjai is offline
post #9 of 10 Old 09-20-2013, 01:43 PM
TwistedT is offline
post #10 of 10 Old 09-20-2013, 11:33 PM Thread Starter
Thanks everyone. Longer screw fixed my issue!
JPilot is offline
