12v Socket bracket INSIDE the cowling ideas - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 24 Old 07-10-2007, 07:59 AM Thread Starter
I'm looking for some ideas about how to mount a 12v socket inside the front cowling/fairing. I know most of you drilled a hole in the cowling and have the socket sitting up top. I'd prefer to have the socket underneath and out of sight. The Garmin Nuvi charger that I'm going to use has a big long stalk on it and I don't want that sticking up in the air. Plus I just prefer this location.
Right now, I'm looking at fabbing a bracket to attach to one of the round bars near the headlight. However, someone may have come up with a better idea. If so, post some pics please.
DL650K5 (Silver)
aircav is offline
post #2 of 24 Old 07-10-2007, 08:15 AM
The gas tank on the left side has a longer projection toward the front than the right side, leaving a nice flat area on the inside. I have a cigarette lighter socket attached there with 3M dual lock.
post #3 of 24 Old 07-10-2007, 11:38 AM Thread Starter
Holy technobabble Batman! I'm an Engineer and it took me a while to figure at what that dual lock stuff was. It's fancy velcro!
That's an idea. I'd still have to make a bracket to provide a surface to attach the dual lock to the socket, since its round. I doubt I'd have enough surface area just using the velcro on the socket body.
DL650K5 (Silver)
aircav is offline
post #4 of 24 Old 07-10-2007, 12:51 PM
I got a socket at Wal-Mart that had a large flat bracket on it and a rubber plug to seal the opening when not in use.
post #5 of 24 Old 07-10-2007, 05:25 PM
Christopher Ryan's Avatar
I mounted two under the seat and one on the black plastic rim of the faring. All sockets are switched with independant rocker switches. I like the look of the setup but my camera is at the cottage.
I do not mind poking holes in this bike. I am going to keep it until the resale value is eroded by 200,000 kms or more.
As I said before, if I can get 200,000kms out of this, I am going to replace it with another.
If you are of the same ilk, poke, drill, cut to your heart's content.
If you do not ride your bike. Keep it clean and perfect. I might want to buy it in 168,000kms
Christopher Ryan is offline
post #6 of 24 Old 07-10-2007, 06:33 PM Thread Starter
Our Wally world usually doesn't stock stuff you commonly find in US stores. I think all they really share is the name.
As for poking holes, I don't do it willy-nilly, but if need be I will. I modified the blank on the throttle housing to hold the switch for my heated grips. However in this case I want the outlet inside. That Garmin adapter is huge and I'd prefer not to look at it every time I ride.
I did find a bracket at the front of the bike with a largish hole 1/2" to 3/4" that might be a good spot. I just have check that I can turn the handle bars lock to lock without hitting the outlet. The steering was locked when I checked.
DL650K5 (Silver)
aircav is offline
post #7 of 24 Old 07-10-2007, 08:52 PM
savvy's Avatar
just got back from wally world and they had what seemed to be the same socket with a flat bracket for mounting. 10 or 12 canadian, had to bribe my daugher to go there with promises of Nemo gummi bears so it actually ended up costing closer to $20
mike
DL1000 K3
author of future books, "Stuck in Pickering" and "Only Cowards Stay Married"
savvy is offline
post #8 of 24 Old 07-13-2007, 10:09 PM Thread Starter
No such luck for me. I've never found anything that's supposed to be at Walmart. Maybe it's just the Ottawa stores.
Anyway, I found a great spot to mount the socket that I'd already bought. I just had to fabricate a bracket for it. I bought a piece of 1/8" x 1-1/4 Aluminum from Home Depot. When I went to make the 90 degree bend the aluminum snapped! Dunno what that was about.
I happened to have some 1/8" steel plate lying around. I broke out the plasma cutter and rough cut a basic shape. Here's what I eventually ended up with (painted with spray-on bed liner):
The bend in the bracket was necessary because the clutch cable would bind up on the socket otherwise.
Here is the bracket with the 12V socket installed.
I attached the bracket behind the cable guide for the clutch.
Looking down from above, the location is out of the way, yet still easy to reach.
Here's a side view to help locate the socket. It's basically level with the bottom of the ignition switch housing.
I hooked the socket directly to the battery via an inline fuse. I have 10A fuse in there for now.
DL650K5 (Silver)
aircav is offline
post #9 of 24 Old 07-13-2007, 10:21 PM
I like it. I take it you have a ground wire going to the battery too.
post #10 of 24 Old 07-13-2007, 11:19 PM Thread Starter
What is this "ground wire" you speak of? :mrgreen:
Yes, I do. I didn't want to hook directly to the battery, since I will be removing the battery for the winter. But I didn't see a better choice. The heavy ground wire attaches to the back of the engine - I could have hooked in there but... nah. The positive wire disappeared under the tank somewhere and I didn't feel like chasing it down.
DL650K5 (Silver)
aircav is offline
