How relays work - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 06-26-2007, 01:06 PM Thread Starter
Dave1's Avatar
Send a message via Yahoo to Dave1
How relays work
http://www.howstuffworks.com/relay.htm
Relays are really cool, I just found out how they work from the above website.
You can use a relay with a 5v activator and use any light bulb run to activate your high amp power panel!
Dave1 is offline
post #2 of 2 Old 06-26-2007, 01:18 PM
SCraig's Avatar
They are cool, but from an electronic standpoint they are slow to switch and bulky. When used properly they are invaluable though.
Their most common use, as you have seen, is to use a low-current source to switch a high-current load. I have a relay on my bike that is switched from the tail light circuit. I use it for my heated grips and a couple of other things that I want to be off when the ignition is off.
Three things to remember with relays:
1) Never exceed the contact ratings. The contacts are rated in amps, and that rating is the maximum current they can handle. Exceed it very much and the relay will burn out, or in rare cases, the contacts can weld together.
2) Size your load wire to handle at least 125% of the contact ratings of your relay. If you have a 30 amp relay use wire that is capable of handling at least 37.5 amps (#8).
3) Put a fuse in series with the load side. The fuse should be slightly less than the maximum current rating of the relay contacts to prevent #1 from happening.
Scott Craig - Nashville, TN
SCraig is offline
