Glee Tip for Installing Eastern Beaver ABS Wiring - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 1 Old 08-19-2013, 11:37 PM Thread Starter
KenZ's Avatar
Thumbs up Glee Tip for Installing Eastern Beaver ABS Wiring
Some have found it necessary to remove the side panel plastic to gain access to the ABS wiring to install Eastern Beaver ABS switch kit. I was able to access the terminal with the panel just loosened in front. Releasing the 25 amp ABS fuse holder from its bracket gives the wiring enough slack to fish the terminal out and up, giving you enough room to make the connections. Then put the fuse holder back. YMMV
"The problem with quotes on the internet is that they're so hard to verify." - Abraham Lincoln
KenZ is offline
Tags
abs , eastern beaver , wiring
