Datel Voltmeter .. Which Model? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 07-04-2013, 01:59 AM Thread Starter
6:45 Orange Sunrise's Avatar
I see a lot of Datel voltmeter threads, but haven't seen one that tells me the model most of you are using.
I'm guessing it's the traditional 2-wire DC voltmeter? I will mostly likely mount it under the PWD radar shelf.
DATEL DC Voltmeters
I don't know much about electrical but (starting with the EB H4 relay and PC-8 kits) I'm learning more and more every day.
Thanks for your help!
'03 CRF230 - '09 DL650 - Orange Wee Club Member #362
6:45 Orange Sunrise is offline
post #2 of 13 Old 07-04-2013, 03:03 AM
PSychoslag's Avatar
I got the DMS-20PC-1-DCM and love it. I almost got the blue one but several people told me that it was obnoxious at night. Didn't want to chance it so I stuck with the red. Also, if you get one with two digits after the decimal point, it can be quite distracting as the numbers almost never stop changing....
PSychoslag is offline
post #3 of 13 Old 07-04-2013, 02:18 PM Thread Starter
I definitely want the 3-digit meter. "13.2" as opposed to the extra digit "13.21"
The part # DMS-20PC-1-DCM (red) says 3 1/2 Digit Red LED. Does the "1/2" mean the second digit after the decimal?
The part # DMS-20PC-2-DCM says 3 Digit Red LED. Meaning one digit after the decimal?
The "view package" under the "Size" column is not specific to the part number.
All show the same generic image. DMS-20PC-DCM Series LED DC Voltmeters
post #4 of 13 Old 07-04-2013, 04:21 PM
PSychoslag's Avatar
The 1/2 means the digit on the far left only has half the segments of the other three.
On the DMS-20PC-1-DCM, the far left digit is not used and there is only one digit to the right of the decimal point. The DMS-20PC-2-DCM has no decimal point.
Check this page out for a good explanation on 1/2 digit displays.
Here's what mine looks like:
2012 DL650 White
2012 DL650 Orange (Totaled)
post #5 of 13 Old 07-04-2013, 05:55 PM Thread Starter
Thank you for explaining that to me, PSychoslag, and thanks for the link too. I was way off! lol
The Meter Center the best place to order from?
Datel Digital Meters Home Page - DatelMeters.com
post #6 of 13 Old 07-04-2013, 06:05 PM
PSychoslag's Avatar
You're welcome!
I don't know if they're the best place to order from but that's where I got mine! They shipped fast and answered questions promptly.
2012 DL650 White
post #7 of 13 Old 07-04-2013, 06:43 PM Thread Starter
All's I need is a good word. I will order from them.
Thanks again!
Next step... how-to use a multimeter to measure voltage, etc... and which inexpensive multimeter to get.
:mrgreen:
post #8 of 13 Old 07-04-2013, 07:13 PM
Voltar's Avatar
For your purposes, any cheap multimeter should do. I would get one that measures resistance (ohms), AC volts, and DC volts.
Here is an example:
7 Function Multimeter
As far as how to measure voltage.... just turn it on and twist the dial to DV Volts (if trying to measure a battery) and select something like the 20V range. Touch the red lead on battery + and the black lead on battery -. You can do this on an AA battery, etc as well. The display should show you the voltage output by the battery.
Voltar is offline
post #9 of 13 Old 07-04-2013, 08:12 PM Thread Starter
Alrighty! There's a Harbor Freight about 15 miles from my house. For $5.29 I'll get two, just in case one breaks... or if I break it. lol
I was looking at brands and models at amazon, Lowe's, Home Depot, Radio Shack and other places, but had no idea what to get. The only thing I knew was I wasn't going get one that cost me more than $30.
There are a number of How-to's on youtube that I will check out. Those lessons should help some.
I'll start with Voltar's first lesson.
Thanks much!
post #10 of 13 Old 07-04-2013, 09:48 PM
Voltar's Avatar
That's the spirit!!!!
If you haven't purchased your daytel voltmeter there are many under $10 (also under $5) options on eBay. It's what I did anyway.
I think you said you were going to use a PWD shelf. See this post for my set up:
https://www.stromtrooper.com/1325937-post40.html
Voltar is offline
