Grounding block location - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 04-26-2007, 12:20 PM Thread Starter
cmosentine's Avatar
Hello all: I am thinking of installing a grounding block. For those who have, what product did you use AND WHERE did you place it on the bike?
Thanks, Chris.
[U]Chris Mosentine [/U]
2008 HD FLSTF
Previous - 2006 Suzuki DL1000, 1993 Kawasaki VN750, Suzuki DL350, 1976 Yamaha DT400, 1977 Honda XR75.
cmosentine is offline
post #2 of 4 Old 04-26-2007, 12:57 PM
A common setup is a Blue Seas combination fuse block and grounding block mounted in the under seat tray. With all the extra plumbing and wiring on my ABS bike with electronic/vacuum cruise control and charcoal canister, it was about the only place.
post #3 of 4 Old 04-28-2007, 08:54 PM
I made a bracket which comes off the left side Rad shroud. There is a hole already there just below the upper mounting bolt. I have a gound wire going directly to the battery to the bracket. I have pics but I haven't figured out how to post a picture yet on this forum, if you PM me your email address I'll send you a pic.
Also made a ground block for under the seat
IslandStrom is offline
post #4 of 4 Old 04-29-2007, 11:06 PM
mcdstrom's Avatar
I did a little looking this weekend, but couldn't find a "grounding block". Did find a terminal strip, but that would have cost $15 which seemed a bit too much for me. So I went with a poor man's grounding block - a bolt. I just using ring connectors instead of spade connectors. Seems to work for now.
2009 DL650A Grey
2004 DL650 Blue - sold
Long ago TC-90
mcdstrom is offline
