LED floodlight relay harness - wiring question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 04-13-2013, 09:27 PM Thread Starter
the schwartz's Avatar
I'm doing something wrong, because the lights don't come on
Anyone (greywolf) mind putting an eyeball on this and tell me where I made stupid?
[QUOTE=Stromin'Nroman;2216938]
If not for it's 500 lb. weight, limited ground clearance, spindly handlebars, close fender fit, short suspention travel, exposed oil filter and forward weigh bias, it would make a great dirt bike.
[/QUOTE]
the schwartz is offline
post #2 of 13 Old 04-13-2013, 09:47 PM
tmcgee's Avatar
Your switch has to provide the coil power for the relay. You need to get ground on one relay pin and +12 on the other. (Pins 85 and 86). I'm going by your drawing, I don't know if you have the right PIN numbers labeled, but conceptually, that's how it works.
tmcgee is offline
post #3 of 13 Old 04-13-2013, 10:04 PM
Here's a wiring diagram for a fuse block. If you only have one device, that would be used instead. Fuses are not shown.
post #4 of 13 Old 04-13-2013, 11:08 PM Thread Starter
that diagram is confusing me because every other thing i've seen online shows 30 as the 12v input. i'd expect the battery (or in my case fused power, PC8 ) to connect to 30.
[/QUOTE]
post #5 of 13 Old 04-13-2013, 11:18 PM
The relay connects 30 and 87 when it throws. Input and output matters not as long as one is the hot source and the other is the hot target. Similarly, 85 and 86 are trigger and ground, it doesn't matter which is which. Here is an SPDT relay. The common SPST relay works the same way but doesn't have a normally closed 87A terminal. 86 and 85 energize the coil to throw the relay. 30 and 87 are connected when the relay is thrown.
post #6 of 13 Old 04-13-2013, 11:46 PM Thread Starter
take 2
[/QUOTE]
post #7 of 13 Old 04-14-2013, 12:09 AM
You have 86 to ground. You need 85 hot to throw the relay so the ? wire has to go to positive, not negative.
post #8 of 13 Old 04-14-2013, 01:24 AM Thread Starter
tada?
gonna try plugging it in tomorrow. thanks as always so much for the experience and info.
[/QUOTE]
post #9 of 13 Old 04-14-2013, 08:43 AM
The Phantom's Avatar
Was just wondering when you finally get them up & running if you could share your thoughts on those lights. I've been looking at them (& others) as an option on ebay.
The mount looks a little iffy in the pics. I'm hoping the quality/quantity of light emitted makes up for it & I just knock up some mounts of my own.
The Phantom is offline
post #10 of 13 Old 04-14-2013, 10:10 AM Thread Starter
be glad to. i bought these locally off a forum member, CrazyGeorge. I'm really looking forward to having them on - i think it's going to make a huge difference at night.
I've seen the lights mounted on his vee and they're impressive.
[/QUOTE]
