SV Racing Parts, Extended Top Front Brake Line Kits for 2012 DL650 abs - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
SV Racing Parts
post #1 of 22 Old 06-08-2012, 10:28 PM Thread Starter
Stromtrooper.com Sponsor
SV Racing Parts's Avatar
Thumbs up SV Racing Parts, Extended Top Front Brake Line Kits for 2012 DL650 abs
Hi Everyone, I am happy to announce that the SV Racing Parts, Extended Top Front Brake Line Kit for 2012 DL650 abs is now Officially Released and Available for use to all Stromtroopers wanting to run GenMar Up and Back or any other Handle Bar Risers on our 2012 and up DL650 abs bikes,
Once again I have teamed up with Galfer to produce another SV Racing Parts, private part number SS Line Kit that will do exactly what we need it do and meets all the Galfer Lifetime Guaranteed Part criteria,
I promised everyone I would post up when the project was ready to ship, and here it is,
This was a tough one to get around due to the fittings and the way Galfer hard plumbed the brake lines together,
We did it with a Great Looking Black SS 3 Line Kit that ties the whole front end together properly for all aesthetic and safety reasons, and provides the right length Top Line for all the common risers, and without having to incur custom line charge fees for the riser heights,
I am sure that some of our members who have already installed the kits from the initial production run will be along shortly to post up how they like the kit.
It is a 3 line kit that comes with all the unique fittings you will require and new replacement SS Banjo Bolts and Crush washers for your bike,
It is priced at $114.99 all in with $10 Flat Rate shipping to your door anywhere in the USA,
As with all the 2007 - 2011 DL650 abs models, the one other item I highly recommend that you order at the same time is the CT Single Banjo Bleeder, $19.95, for your Front Brake Master Cylinder, it will make bleeding and maintaining your 2012 DL650 abs system so much easier. Your brakes and your bike will thank you,
You can find the 2102 DL650 abs Black SS Line Kits on the website SVRacingParts.com Under the category For Stromtroopers, and then Under Brake Products,
If you need and help at all Email me Directly at [email protected] and I will get you looked after right away,
These parts will serve you well,
Blair
SV Racing Parts is offline
post #2 of 22 Old 06-08-2012, 10:58 PM
andreas's Avatar
Kit came in a couple days, fast shipping as usual for Blair. Took me about 5 hours, didn't really know what I was doing at first, but now I could do it in an hour. If you know the bike you might be able to do it with out taking the tank off, Suzuki made it hard to take the bike apart.
Wife loves the risers, no more leaning forward. If someone has questions please ask. I'll post some pics later.
FB MEMBER #133 - 2008 Wee
andreas is offline
post #3 of 22 Old 06-09-2012, 12:03 AM
I have them on my bike and they are great. I was able to with risers finally able to put the handlebars where I like them. I know others who have lowered the bike to get more clearance to mount risers but this way you do not have to lower.
Respectfully, Doug
1 deadeye is offline
post #4 of 22 Old 06-24-2012, 09:12 PM Thread Starter
Blair
post #5 of 22 Old 06-24-2012, 11:10 PM
glasswave's Avatar
Thanks Blair!
Any eta on a 2012 dl650 specific mount for the Scotts stabilizer?
[SIZE="1"]Trips:
Indian Himalaya:Gangotri-Shimla-Manali-Pavarti-Spiti-Leh-Kargil-Padum-Sringhar-Daramsala (3 mo.--2x)
Kazakstan-Krygyzstan-Tajikistan-Xin Xiang to Lhasa, Tibet on China 219!-Nepal (7 months)
Santiago, Chile to Ushuia Argentina and up to Cusco, Peru (7 months)
Peruvian Andes (3 months)
N Chile - Medellin, Colombia (3 months)
Cartegena, CO to N Chile (3 months)[/SIZE]
glasswave is offline
post #6 of 22 Old 06-24-2012, 11:15 PM Thread Starter
Hi, Thanks, the 2012 DL650 abs Lines Kit was a challenge but this is a super elegant upgrade that will all every Stromtrooper to run the risers of their choice with no issues,
On the Scotts Stabilizer Mount for the DL650 abs you can be sure Santa has his elves working on that as an early Christmas present for all the good girls and boys,
I will post up as soon as it is released and available,
Blair
post #7 of 22 Old 06-25-2012, 09:24 AM
Blair,
did u take any pics when you test fit the kit to a stromer' bike?
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
post #8 of 22 Old 06-25-2012, 09:39 AM Thread Starter
Hi Ace, There are a number of photos done up and posted by Stromtroopers who have installed the kit at home, I will get some of them organized and post up a few,
The Kit comes with very good instructions on exactly how to set up and install the lines, The one other item that I do highly recommend be ordered at the same time is the CT Single Banjo Bleeder to allow the brakes to be bled and maintained from the top,
It makes the initial process and the ongoing maintenance of the DL650 abs brakes so much easier,
This is a very good solution to the short front brake line from Suzuki and being able to install the handle bar risers of your choice,
Blair
Enjoy
post #9 of 22 Old 06-25-2012, 07:48 PM
Do you know what's the approximate extension available with the OEM (handlebar / risers) setup before this kit is needed?
That is, can I put a 30mm up 'n back farkle in before I need this kit? Or, what's the approximate limit before I need to buy this?
Is there anything else that need to be changed at the same time? (clutch? throttle cables?)
Thanks...
2007 Suzuki DRZ400-S
2012 Suzuki DRZ400-S (sold)
2012 WeeStrom
2012 Kaw ZX-14R
2013 Yam WR450F (sold)
mebgardner is offline
post #10 of 22 Old 06-25-2012, 08:04 PM Thread Starter
Hi, if you go anymore than a very simple One Up Riser you need to swap out the Front Brake Line on your DL650 abs to this kit. Otherwise you are stressing the brake hose connectors with too much stretch and they will eventually just give out and separate which is not what you want,
You can order Black SS Extended Brake Lines Kit in two versions so do let me know what you are doing for risers and I will ship you the appropriate version,
I have a lot of experience gleaned over past 5 years since DL650 abs was introduced and we started doing these kits up for our bikes back in 2007,
I have set up the drop down boxes in the website at SVRacingParts.com to make is as simple as possible for everyone,
I am keeping the kits in stock and ready to ship immediately,
Let me know whenever I can help you out, If you email me at [email protected] and include a contact phone number I will be happy to give you a brief call to discuss your needs and the best solution for you,
Blair
