Sag / Preload setting on lowered Wee? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 10-06-2012, 10:55 PM Thread Starter
Rainman901's Avatar
Simple question I hope.
I lowered my Wee (2012) about a month ago, using 1" lowering links and raising the forks. My question is, when setting Sag, can I use the stock numbers in the manual or do I need to take the lowering links into effect?
I've never measured or set the sag so I would like to see where I am and make changes if necessary but this has me puzzled. Did I mention I tend to over analyze stuff?
I searched I really did..... If you have a link feel free to post it and I will hang my head in shame.
Thanks,
Ray
DL650AL2 "WEE" Strom, (I'll never call it a Glee, noob or not).
Grip Puppies; SW-Motech Center Stand; SW-Motech Crash bars; Touratech Skid Plate; Bike Viz Bullets; Stebel Nautilus and a Front Fenda Extenda. Ebay special Brake and Clutch Levers; Wolfman Explorer Lite tankbag; Givi V46 TopCase.
Rainman901 is offline
post #2 of 6 Old 10-07-2012, 12:26 AM
RichDesmond's Avatar
Thanks,
Ray
The manual has sag numbers??
Regardless, 40mm of total sag is still good.
Rich Desmond
RichDesmond is offline
post #3 of 6 Old 10-07-2012, 02:38 AM
2stroked's Avatar
if you lowered your bike an 1" I would take the stock sag #'s and figure what the sag should be with an 1" less travel, if the sag is 25% with 5.5" of travel it should still be 25% with 4.5" of travel. If you are too fare through the travel it will feel harsh because you are compressing the air volume in the forks and the shock it will bottom more, not as critical on our bikes because the suspension is so basic.
2stroked is offline
post #4 of 6 Old 10-07-2012, 10:00 AM
A lowered bike doesn't have less travel unless the shocks and forks are altered, a rare occurrence. Raising the fork tubes in the clamps has no effect on travel and changing the dog bones has a negligible effect. 40mm is still fine.
post #5 of 6 Old 10-07-2012, 12:50 PM Thread Starter
Rainman901's Avatar
Thanks for the quick replies. Looks like I'll be going for 40mm.
BTW, The "info" I meant in the manual was the suspension travel, not sag.
Thanks again,
post #6 of 6 Old 10-08-2012, 10:55 PM
2stroked's Avatar
Duh, didn't even occur to me about the lowering links, not shortening the shock or fork travel.
2stroked is offline
