Front Fork Brace - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 25 Old 09-18-2012, 06:59 PM Thread Starter
Front Fork Brace
Okay so I know a lot of people swear by this thing. I'm just wondering what you guys think it really does or doesn't do for you? I've ridden a lot of bikes and haven't noticed that my Wee is unstable or has any wobble up front. Also it has ABS if that matters. Thanks
2009 DL650A
Vikingr is offline
post #2 of 25 Old 09-18-2012, 07:01 PM
Jarlaxle28's Avatar
Hell if I know. My fork brace has been on so long that I forgot what it handled like without it.
[I]When you think of the long and gloomy history of man, you will find more hideous crimes have been committed in the name of obedience than have ever been committed in the name of rebellion.[/I]
- C. P. Snow
Jarlaxle28 is offline
post #3 of 25 Old 09-18-2012, 07:28 PM
Since the front forks are longer than most road bikes you get more twisting around of the forks under force.
What you'll notice is more precision in turns and less affected by cross winds or dirty air (tracks straighter).
2009 DL650
Stromburger is offline
post #4 of 25 Old 09-18-2012, 07:37 PM
honez's Avatar
I noticed a marked difference in cornering feel (for the better) when I put mine on and it's been on ever since. I didn't particularly notice that much instability at highway speeds in cross winds/ buffeting, but when I put it on I hadn't done any really long stretches on the highway so I can't really compare the before and after with any degree of reliability.
What I do know now though, is that I'm very happy with the cornering stability and there's no real issues at speed from my fork-braced set up, so I'm not about to go mucking around and remove it. It's on, seems to be doing the business, so it's staying put.
honez is offline
post #5 of 25 Old 09-18-2012, 07:38 PM Thread Starter
Thanks stromburger. Now that you mention it, I do get some wobble/instability above 70mph especially on the slab. Also, thanks honez. I can see one in my near future.
2009 DL650A
Vikingr is offline
post #6 of 25 Old 09-19-2012, 11:15 AM
Forks flex. When they flex, they stick-slip-stick-slip, etc. The best forks flex less, and Suzuki doesn't put the best forks on bikes that sell for the price of our stroms. A fork brace helps reduce fork flex and lets them do their job more smoothly.
The ABS brake distribution fitting can get hit by a fork brace. The Superbrace with its raised center is reduces the clearance even more. One of the straight braces (Richland Rick's, Murph's) works well, and then limit the amount the forks are raised to about 10 mm. All three brands are OK if you don't raise the forks.
post #7 of 25 Old 09-19-2012, 12:28 PM
lordneeko's Avatar
It was easy enough just to copy and paste my other responses to this.
I would like to add a +1 to this. Not everyone notices the difference...but take some turns through a pot hole or over a man hole cover and you'll feel that front end wobble a lot..get a fork brace!
2006 Vstrom 650
1999 Triumph Trophy 1200
2012 Vstrom 650 (current)
lordneeko is offline
post #8 of 25 Old 09-19-2012, 12:40 PM
Scott E. Bonds's Avatar
Before the move to inverted forks many bikes came from the factory with a fork brace. I put the difference you will feel with one about like the difference between radial and bias ply tires. It is subtle, but if you are "at one with your bike" you can tell the difference.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
post #9 of 25 Old 10-01-2012, 11:52 PM
My first farkle was a fork brace. Noticeable. Awesome.
2008 dl1000
trex is offline
post #10 of 25 Old 10-02-2012, 09:38 AM
drrod's Avatar
I also found that the brace made the bike more stable on gravel and dirt roads.
Big improvement.
Rod
drrod is online now
