First ride on the dark side - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 40 Old 09-03-2012, 10:40 PM Thread Starter
This morning i mounted a 205 50R/17 General Altimax Artic on the rear of the V Strom. Today I rode about 150 miles of mostly mountain twisties (dragon and Cherohala Skyway). Some dry roads and some wet roads and even a couple of miles of a muddy/gravel road with some tight turns and grade changes.
I have a Tourance on the front and removed a Tourance from the rear to put the CT on. The CT requires " just a little bit" more counter-steering to get the bike tipped over. At first the bike felt wobbly when leaned over but, that was corrected by dialing in a a few more clicks of rebound and compression damping on my Ohlins shock. The CT is much heavier then a MC tire. I agree with Randyo who stated that an aftermarket shock is a big help with a CT. I think the stock shock would be overwhelmed. The damping adjustment settled things down and the bike feels about 95% as good as it did with the MC tire. I may change that to 110% as good after some more saddle time with the CT
Although I did not push too hard, as this was my first ride with the CT, traction seemed better then the Tourance. I can feel the Tourance start to slip on hard corner exit acceleration. The CT did not slip while acceleration hard out of corners. Also off pavement traction was notably better although the extra weight caused the suspension to not work as well over rough terrain.
Why did I do this? 90% of my riding is in the mountains at a sporting-semi sporting pace. I was killing rear MC tires every 2500 miles. That gets expensive. Several people here who obviously know what they are talking about have reported good results with CT's. I had to try it. Glad that i did. Thanks to those who took the heat and reported their findings.
'02 DR 650
'01 Aprilia Mille
'07 DL1000
Marty is offline
post #2 of 40 Old 09-03-2012, 10:43 PM Thread Starter
I shroud add that mounting the CT was considerably more difficult then mounting a MC tire. I used a ratchet strap over a 2x4 block to hold the beads in the drop center then used my no mar bar as usual. It took me maybe 20 minutes after getting the procedure down. I can do a MC tie in 3 minutes.
'02 DR 650
'01 Aprilia Mille
'07 DL1000
Marty is offline
post #3 of 40 Old 09-04-2012, 06:37 AM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
I used my knees to keep the tire in the center.
Found it easy to mount the CT.
Mike
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
post #4 of 40 Old 09-04-2012, 08:20 AM
kenneth_moore's Avatar
"Fist Ride on the Dark Side?"
Geez dude, this is a family-safe website.
(Not that there's anything wrong with that...)
Go hakafugu yourself.
kenneth_moore is offline
post #5 of 40 Old 09-04-2012, 12:12 PM
strom lurker's Avatar
It seems some guys are just a bit more hard-core than others.
Current Stable:
1971 Honda CB500 Cafe Racer
1974 Honda CB550
1975 Honda CB750
1981 Honda Goldwing
1993 Yamaha GTS-1000 x3
2000 Hayabusa
2003 V-strom
strom lurker is offline
post #6 of 40 Old 09-05-2012, 10:34 AM
GlenT's Avatar
Let's hope that your side walls last as long as the tread. You are, by far, a braver man than I.
2013 Tiger Explorer 1200
2009 DL650 ABS
2004 Honda ST1300
GlenT is offline
post #7 of 40 Old 09-05-2012, 12:43 PM Thread Starter
The side wall never touches the road.
'02 DR 650
'01 Aprilia Mille
'07 DL1000
Marty is offline
post #8 of 40 Old 09-05-2012, 01:06 PM
GlenT's Avatar
No, but putting that tire on a motorcycle, causes the side wall to flex in ways that it was never designed for. That's the only way that the flat tread cross section can maintain contact with the road when you lean into a turn.
2009 DL650 ABS
2004 Honda ST1300
GlenT is offline
post #9 of 40 Old 09-05-2012, 02:52 PM Thread Starter
I am sure that you are correct but, that is not to say that it does not work well in practice within reasonable limitations.
'02 DR 650
'01 Aprilia Mille
'07 DL1000
Marty is offline
post #10 of 40 Old 09-05-2012, 04:00 PM
GlenT's Avatar
Not saying that it doesn't work well in practice. But what would keep me awake at night, would be the chance that the sidewall might overheat or weaken over time and blow out one day while you are chasing the Dragon.
2009 DL650 ABS
2004 Honda ST1300
GlenT is offline
