New Tourances and now front doesn't feel stable - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 07-14-2012, 08:19 AM Thread Starter
I recently replaced the original stock tires with a set of Tourances. I like the rear but now have a shutter in the front end when taking sweeping turns at speed. Nothing crazy but enough to notice and give me a bit of worry. Going straight no issues, steering is nice and smooth
Is this common with the Tourances or could it be an issue with tire balancing or installation?
mph67 is offline
post #2 of 9 Old 07-14-2012, 08:25 AM
I had a problem with a Tourance EXP on the front. Finally at the end of it's life and crazy wear pattern I realized it had been mounted backwards. Check the arrows on the side walls for proper direction of rotation. I have found Tourance to be a very high quality tire. But you can have problems with anything.
2009 DL650
Stromburger is offline
post #3 of 9 Old 07-14-2012, 10:39 AM
RichDesmond's Avatar
I had exactly the same experience. Put on a set of Tourances and immediately had a front end wobble in the 35-40mph range. Most noticeable on decel but even at steady throttle leaned over in a turn at that speed (like an on-off ramp) you could feel the back and forth motion of the bars. HATED those tires. A set of Conti Attacks did the same thing. Now on Michelin PR3s, which are great.
Rich Desmond
RichDesmond is online now
post #4 of 9 Old 07-14-2012, 10:47 AM
V-Tom's Avatar
First, welcome aboard! You might also want to chekc out the Canadian Forum as you might find some local riders there.
I went through four tourance's (non EXP) on the front of my DL650 and rather like them, but everyone's taste is different.
They are a rounder profile, which in my experience is a contributing factor to the front-end low speed wobble (which was cured on my 2006 DL650 by installing roller bearings.)
The tires gave me great confidence on that bike when combined with lowering the front of the bike/raising the forks about half an inch. I have put on the Tourace rear on my 2012 but the front is still stock and I can't wait to wear it down and get a Tourance there.
One other thing.. what model and year of bike? What tire pressures are you running? I like about 40psi front and 42 psi rear.
..Tom
SMIDSY detailed report.
V-Tom is offline
post #5 of 9 Old 07-14-2012, 12:24 PM
dtalk's Avatar
My two sets of Tourances have given me great service, but they do that. It gets much worse as they age.
Bridgestone Battlewings have been much less wiggle-prone, but the biggest factor is steering head bearings. Keep 'em adjusted correctly; perhaps even a smidge firmer than the service manual says.
Tapered roller bearings for the head, by all accounts, are "the" solution. I will strongly consider switching to those if I ever need to replace them again.
dtalk is offline
post #6 of 9 Old 08-06-2012, 02:51 AM
strom lurker's Avatar
Same here. I have about 2k on them now and they still feel jittery in corners. They are mounted correctly and I keep the psi at 36/38. There's no issue with it holding corners it just doesn't feel planted. However, the tire still looks really good. I was willing to give up a little feel for mileage.
Current Stable:
1971 Honda CB500 Cafe Racer
1974 Honda CB550
1975 Honda CB750
1981 Honda Goldwing
1993 Yamaha GTS-1000 x3
2000 Hayabusa
2003 V-strom
strom lurker is offline
post #7 of 9 Old 08-06-2012, 07:12 AM
ockerstrom's Avatar
Multiple sets of Tourance [originals, not EXP] have gone on the Wee now.
No issues, other than with the current set the front was not balanced properly.
If you have had two sets of different brand tyres fitted at the one place and both are giving problems then change your tyre fitting company.
Ock. in Oz
I ride naked and unafraid.
Windsor (near enough)
NSW
Australia
ockerstrom is offline
post #8 of 9 Old 08-06-2012, 12:14 PM
Scott E. Bonds's Avatar
My (tourances) shook on the Vee's front end also. I loved the rears but two different fronts had a wobble that got worse with mileage. I made the switch to anakee 2s now. I prefer them much better in the front. I hope the rear anakee lasts a long time though...the tourances sure did.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
post #9 of 9 Old 08-06-2012, 12:16 PM
Front Tourances are often reported to cause wobble, Contis too.
Tags
front tire , tourances , wobble
