Today's delivery - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 14 Old 11-25-2019, 01:46 PM Thread Starter
slovcan's Avatar
Today's delivery
I've been anxiously awaiting these. Shinko 804/805. I got them from TORKmoto ( https://torkmoto.ca/ ) $231 CAD delivered including tax. The first thing I did was check the date codes - one was the first week of June 2019 and the other was still warm mid-September. Delivery was less than a week. Excellent.
Cheers,
Glenn
DesertBike and SuperG like this.
Anything can happen in Formula 1 and usually does! - Murray Walker
Here - 2002 V-Strom DL1000, 1999 Triumph Trophy 900, 2003 Maxima SE 6-Speed, 1997 Silverado K2500 - 454
Slovakia - 2004 Rover 75 CDT Tourer w/ Tuning Box
Past - 1977 Honda 400/4 Supersport, 1982 Honda CB900 Custom, 1984 Honda V65 Sabre (TWICE), 1996 Kawi GPz1100, 1990 Honda VFR750F
slovcan is online now
post #2 of 14 Old 11-25-2019, 06:19 PM
I mounted the rear 805 on my 04 Wee and was pleasantly surprised with the handling. Haven't had the chance to wear out the tread yet.
slovcan likes this.
post #3 of 14 Old 11-26-2019, 08:41 PM
I'm on my third set of these and remain thoroughly impressed with their grip on both two-track dirt/gravel and even more so on pavement. Even with the big chunky side blocks, they grip exceptionally well on dry pavement and acceptably in the wet. When pushing them hard in the twisties (as in, hard enough to scrape pegs) they tend to get hot and start to squirm a bit--they're definitely NOT sport tires. I typically get about 3500-4500 miles before I want to change them out.
notacop likes this.
badjuju is offline
post #4 of 14 Old 11-26-2019, 09:06 PM Thread Starter
slovcan's Avatar
Hi badjuju. I'm hoping to get them mounted in the next couple of days. Most of their use will be pavement, but there will be occasional dirt & gravel roads. In the near future - well, next summer - I expect a lot of broken up and poorly maintained paved roads to be my focus.
Cheers,
Glenn
post #5 of 14 Old 11-26-2019, 09:36 PM
PerazziMx14's Avatar
Big block tires can handle. I was surprised by TKC 80's and how they stick to pavement. Have not tried the 804/5's yet. Still stuck on 705 for general purpose everyday tire.
PerazziMx14 is offline
post #6 of 14 Old 11-27-2019, 11:20 AM
tenny80's Avatar
Cheers,
Glenn
For your use you might want to consider the 705 once you wear these guys out. I found the 805's do not last very long, are loud on the highway and can get a bit squirelly in the tar snakes once they are worn down a bit. I am not sure on the older years/650 but on the 2014+ 1000's you need to use a fender riser with this tire. Adventuretech makes them and I think it runs about 100 bucks canadian by the time you get it. Otherwise the tire will ruin your fender.
2018 Vstrom 1000
tenny80 is offline
post #7 of 14 Old 11-27-2019, 12:33 PM
Motor7's Avatar
I don`like my 805 front off pavement. Very squirrelly feels like it's trying to wash out even on gentle turns(even aired down). On pavement it's fine. I going to try the new E07 + front that is out now.
15 DL650XT
Motor7 is offline
post #8 of 14 Old 11-27-2019, 06:40 PM Thread Starter
slovcan's Avatar
Thanks guys. I hope to have more info in a couple of days when I get them mounted up. I have a couple of dirt roads I like for a test ride. One in particular that the worn Pilot Roads really didn't like. Of everything I've read about the road noise, about half the reports say the 705s are noisier than the 804/805s. So that's a toss up. I'll find out what they're like on mine and go from there. I WAS going to go wit the 705s until someone here suggested I try these. We'll see and I'll report back. I'll start at 33 psi front and rear.
Edit: Oh yeah, mine is a 2002 DL1000. I don't think there is a fender interference issue with the first gen, but I'll check it when I put the tires on.
Cheers,
Glenn
post #9 of 14 Old 12-01-2019, 01:09 PM
Cheers,
Glenn
Assuming the front fender is same or similar on the Wee and the Vee, it'll fit just fine. I have an '09 Wee and there's plenty of clearance. I typically run 32-34 front and 34-36 rear. Drop the pressure a pound or two when riding in very cold weather (<35*F) and bump it a bit in the summer when temps are high and/or you're running at speed on the x-way. I run 38-40 in the rear when touring loaded with luggage. On the big Strom, you'll prolly be lucky to get 3500 miles on the rear unless you have a very light right hand. I haven't noticed the low-speed "buzz" to be any different on the 80X vs the 705. No buzz at all once your speed gets above 25-30 MPH.
badjuju is offline
post #10 of 14 Old 12-01-2019, 07:05 PM Thread Starter
slovcan's Avatar
Cheers,
Glenn
OK, thanks all. I got them mounted up today so should get them reinstalled tomorrow for a test ride. Temps here now are usually 0*C +/- 2*C or so - freezing. I'll start at 33 psi and drop a couple from there if I feel any sort of cold rubber slippage. BTW, I checked the inside of both tires and there were not any silver foil patches (or any other colour). Both tires were made in the past 5 months, so maybe that's a thing of the past.
Cheers,
Glenn
