Rabaconda Motorcycle Tire Changer - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 11 Old 08-21-2019, 01:41 PM Thread Starter
Just wondering if anyone here has one or used one? I've got a "Overfilled" garage according to the trophy wife and no where to house a Harbor Freight tire changer. The Rabaconda set's up and tears down quickly. I know it's a little spendy, but cheaper than another addition to the garage. What's been your experience? Thanks in advance
Ten words to make you successful in no matter what you do
"Show up, On time, Every day, Work your butt off"
Jmrgates is offline
post #2 of 11 Old 08-21-2019, 02:03 PM
dravnx's Avatar
I've never used one but I watched the video of the stand in action. It's basically a bead breaker and a stand. You're still mounting and dismounting the tire with irons.
DesertBike likes this.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
dravnx is offline
post #3 of 11 Old 08-21-2019, 04:16 PM
Does it look to be much easier?
RLBranson is offline
post #4 of 11 Old 08-21-2019, 04:23 PM
"Scuze me, How does a Trophy Wife even care a manicure about what happens in the garage?
If you make room for her Jag what else would she care?
Trophy Wife means you have the means to keep her!
I married a Homemaker and have had the 3 car to myself for 48 years.
post #5 of 11 Old 08-21-2019, 05:16 PM
dravnx's Avatar
I started with an HF tire changer and a No Mar bar. Upgraded to a No Mar Classic. Had that for a few years and then ran into a great deal on a swing arm automatic tire changer. Life is now sweet. If space is an issue the No Mar can be hitch mounted so it can be broken down and stowed when not in use. A lot of the Adv type tires have pretty stiff side walls and can be a struggle to demount and mount.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
dravnx is offline
post #6 of 11 Old 08-21-2019, 07:04 PM
It is nice that you have owned some tire changers but you mentioned that you had seen a video if a new one in action.
Did the new one seem to be easy to use ?
post #7 of 11 Old 08-21-2019, 07:47 PM
dravnx's Avatar
If you can or have changed a tire using tire irons, it's a marginally easier process, otherwise, I don't see the value in it.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
dravnx is offline
post #8 of 11 Old 08-22-2019, 01:13 AM
I'm not sure what you're talking about? Perhaps you can post several pictures...one or two shots of the Rabaconda tire changer could be useful too...
gdrew is online now
post #9 of 11 Old 08-22-2019, 09:10 AM
Big Boy's Avatar
https://www.amazon.com/Rabaconda-Mot...21915352&psc=1
W. C. Fields
Big Boy is offline
post #10 of 11 Old 08-31-2019, 07:33 AM
Motor7's Avatar
^ That's just a bead breaker and stand, so yeah tire irons after that. Might be fine for road tires, but no way would I try and mount E07's or K60's with irons. Been there, done that won't do it again.
Every time I use my HF w/Mojo Blocks and No Scuff tire tool I get it done a little faster with less grunt. Yes it takes up some room, but as stated a hitch mount would be the way to go and keep it out of the way when not in use. A 3' length of 2" receiver tube and a welder can fix you up pretty cheap. Make sure the stand is mounted at ground level so you can use the built in bead breaker...it's indispensable.
'15 DL650XT
Motor7 is offline
