Another Tire Pressure Thread - Shinko 804/805 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 28Likes
post #1 of 32 Old 04-16-2019, 10:40 PM Thread Starter
Webfors's Avatar
What do you run your Shinko 804/805's at on a DL650?
I've put the rear at 40. I'm really surprised how well this tire behaves on pavement.
Big B and KSM like this.
Two wheelz for realz!
Webfors is offline
post #2 of 32 Old 04-16-2019, 10:57 PM
tucsonray's Avatar
40 is good. Those tires are amazing on pavement! At least considering how knobby they are
Big B and Webfors like this.
tucsonray is offline
post #3 of 32 Old 04-17-2019, 09:37 AM
I agree with the handling, at least in the dry. Better than the 705 in the twisties. Haven't had the chance to ride them to death so i can't vouch for mileage.
Webfors likes this.
post #4 of 32 Old 04-17-2019, 09:43 AM Thread Starter
Webfors's Avatar
What about the front? I haven't installed the 804 yet due to life on my OEM TW left. I currently have the OEM TW running at 36.
Webfors is offline
post #5 of 32 Old 04-17-2019, 10:16 AM
eff
eff's Avatar
OK, I have to ask, why run the pressure so high? Recommended pressure is 33 psi front and 36 psi rear.
KSM likes this.
2007 V-Strom 650
2004 GasGas EC250
eff is offline
post #6 of 32 Old 04-17-2019, 12:51 PM
Gert's Avatar
A too low tire pressure generates heat (tire wear), while too high tire pressure quickly looses road grip. The trick is to find a happy medium. An on-road test, check tire pressure before going for a ride, stop and take pressure again. If memory serves (open to correction), the pressure should be within 5 - 7 psi of the cold pressure. Another rough indicator is to go for a ride, just a mile or two, get off and feel whether the tire feels hot or just warm. Change the pressure and do the same test again. Or you can follow suggested tire pressures as per the owners manual.
https://www.designcorse.com/blogs/ne...-tire-pressure
Webfors likes this.
Gert is offline
post #7 of 32 Old 04-17-2019, 01:31 PM Thread Starter
Webfors's Avatar
Cold weather, less expansion due to lack of ambient heat, is one consideration. I'm leaving for work at 0-5 degrees lately.
Webfors is offline
post #8 of 32 Old 04-17-2019, 01:32 PM Thread Starter
Webfors's Avatar
Thanks.
Keep in mind the manual states 42psi in the back when 2up and tripping with gear, so weight plays a factor which the default 36psi doesn't account for.
Webfors is offline
post #9 of 32 Old 04-17-2019, 01:46 PM
I had the tire pressure monitors on my 800ST BMW. I didn't notice the pressure fluctuating as I traveled. i normally set the street tires at 36/42 cold and forgetaboutit.
That's riding just me or loaded with the chit for camping
Webfors likes this.
post #10 of 32 Old 04-17-2019, 06:23 PM
Originally Posted by Webfors View Post
Thanks.
The pressures in the manual would be for the stock OEM tires, not the Shinko's.
StratStrom is offline
THE Tire Thread MightyShep Suspension and Tire Tech 1012 08-17-2019 01:20 AM
Off road tire pressure dustbuster DL1000 from 2002-2012 11 06-06-2016 05:11 PM
FOBO BIKE Tire Pressure Monitoring System gunnels Techy World! GPS, Electronics, etc 15 08-30-2015 07:07 PM
Tubetype Tire Without a Tube? FredRider Maintenance, Tech and Products. 6 02-16-2015 06:25 AM
